Datasheet Linear Technology LTC1597BIG#TRPBF — Даташит
Серия | LTC1597B |
Модель | LTC1597BIG#TRPBF |
16-битный параллельный умножающий ЦАП с низким уровнем выбросов и 4-квадрантными резисторами
LTC1591/LTC1597: 14-Bit Parallel Low Glitch Multiplying DAC with 4-Quadrant Resistors Data Sheet
PDF, 513 Кб, Файл закачен: 22 авг 2017
![]() 12 предложений от 12 поставщиков Микросхема Преобразователь DA, LTC1597 - 16Bit Parallel Low Glitch Multiplying DAC with 4-Quadrant Resistors; Package: SSOP; Pins: 28; Temperature Range: -40℃... | |||
LTC1597BIG#TRPBF Linear Technology | 1 766 ₽ | ||
LTC1597BIG#TRPBF Analog Devices | 2 247 ₽ | ||
LTC1597BIG#TRPBF Analog Devices | по запросу | ||
LTC1597BIG#TRPBF Linear Technology | по запросу |
Корпус | SSOP-28 |
Код корпуса | G |
Индекс корпуса | 05-08-1640 (G28) |
Bits | 16 bits |
DAC INL | 2 LSB |
DACs | 1 |
DNL | 1 LSB |
Экспортный контроль | нет |
Ext Vref Range | 0V to В±25V |
Glitch Impulse | 2 nV•s |
I/O | Parallel |
Max Gain Error | 0.04 % FSR |
Max Offset Error | 2.44 мВ |
Output | Current |
Output Range | 0V to 10V, 0V to -10V, В±10V |
Power | 0.055 mW |
Power-On-Reset | Zero-Scale |
Время установления | 2 µs |
Диапазон напряжения питания | 5V |
LTC1591 LTC1591 LTC1597 LTC1597A
- Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74PDF, 980 Кб, Файл опубликован: 1 июл 1998
DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.Выписка из документа
Design Notes
- Selecting Op Amps for Precision 16-Bit DACs &mdash DN214PDF, 76 Кб, Файл опубликован: 1 окт 1999Выписка из документа
Статьи
- Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT JournalPDF, 262 Кб, Файл опубликован: 1 авг 1998Выписка из документа
- 16-Bit Parallel DAC Has 1LSB Linearity, Ultralow Glitch and Accurate 4-Quadrant Resistors &mdash LT JournalPDF, 118 Кб, Файл опубликован: 1 фев 1999Выписка из документа
- A Composite Amplifier Topology Wrings More Performance Out of the LTC1597 16-Bit Current Output DAC &mdash LT JournalPDF, 146 Кб, Файл опубликован: 1 мар 2002Выписка из документа
- Dual Operational Amplifier Combines 16-Bit Precision with High Speed &mdash LT JournalPDF, 230 Кб, Файл опубликован: 1 май 2000Выписка из документа
- LT1468: An Operational Amplifier for Fast, 16-Bit Systems &mdash LT JournalPDF, 221 Кб, Файл опубликован: 1 ноя 1998Выписка из документа
Серия: LTC1597B (8)
- Data Conversion > Digital-to-Analog Converters (DAC) > Current Output DACs | Unipolar Digital-to-Analog Converters (DAC) | Bipolar Digital-to-Analog Converters (DAC)
LTC1597BIGTRPBF, LTC1597BIG TRPBF
