Datasheet Linear Technology LT1117CM-5#TRPBF — Даташит
СерияLT1117
МодельLT1117CM-5#TRPBF
Положительные регуляторы с малым падением напряжения 800 мА, регулируемые и фиксированные 2.85V, 3.3V, 5V
Datasheet LT1117, LT1117-2.85, LT1117-3.3, LT1117-5
PDF, 193 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 16
800mA Low Dropout Positive Regulators Adjustable and Fixed 2.85V,3.3V, 5V
15 предложений от 15 поставщиков
IC REG LINEAR 5V 800MA D2PAK-3. Linear Voltage Regulator IC Positive Fixed 1 Output 800mA D2PAK-3. PMIC - Voltage Regulators -...
LT1117CM-5#TRPBF
292 ₽
LT1117CM-5#TRPBF
LT1117CM-5#TRPBF
LT1117CM-5-TRPBF
КорпусDDPAK-3
Код корпусаM
Индекс корпуса05-08-1460
Design ToolsLTspice File
Discrete Pass Elementнет
Dropout Voltage1.1 В
Экспортный контрольнет
Isupply5 мА
Max Junction Temp125 Deg
Количество выходов1
Выходной ток0.8 A
Выходное напряжениеAdj, 2.85, 3.3, 5
PSRR75 дБ
Theta JA15В°C/W (ST), 10В°C/W (M)
ТипNPN
Vin Max15 В
Vin Min2.45 В
Vout Max13.7 В
Vout Min1.25 В
  • Linear Technology Magazine Circuit Collection, Volume 1 &mdash AN52
    PDF, 190 Кб, Файл опубликован: 1 янв 1993
    This application note consolidates the circuits from the first few years of Linear Technology magazine into one publication. Presented in the note are a variety of circuits ranging from a 50W high efficiency (>90%) switching regulator to steep roll-off filter circuits with low distortion to 12-bit differential temperature measurement systems.
  • 5V to 3.3V Converters for Microprocessor Systems &mdash AN58
    PDF, 310 Кб, Файл опубликован: 1 сен 1993
    Many popular microprocessors operate from 3.3V supplies, yet they are used in systems where the predominate source of power is 5V. AN58 presents a collection of both linear and switching regulator solutions for conversion of 5V to 3.3V at currents ranging from 100mA to 20A. Applications information and a comparison of various bypass capacitor types is included. Most of the designs can be easily modified for other intermediate voltages such as 3.45V, 3.7V, and 4.1V.
Design Notes
  • Active Termination for SCSI-2 Bus &mdash DN34
    PDF, 74 Кб, Файл опубликован: 1 май 1990
  • Techniques for Deriving 3.3V from 5V Supplies &mdash DN74
    PDF, 73 Кб, Файл опубликован: 1 сен 1993
  • 5V to 3.3V Regulator with Fail-Safe Switchover &mdash DN82
    PDF, 74 Кб, Файл опубликован: 1 май 1994
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
LT1117CM-5TRPBF, LT1117CM-5 TRPBF, LT1117CM5#TRPBF, LT1117CM 5#TRPBF
На английском языке: Datasheet Linear Technology LT1117CM-5#TRPBF
Публикации по теме
