Datasheet Linear Technology LT1575CS8-2.8#PBF — Даташит
СерияLT1575
МодельLT1575CS8-2.8#PBF
Сверхбыстрый переходный отклик, регулируемые и фиксированные регуляторы с низким падением напряжения
Datasheet LT1575, LT1577
PDF, 320 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 20
Ultrafast Transient Response, Low Dropout Regulators Adjustable and Fixed
22 предложений от 19 поставщиков
IC LNR REG CTRLR 1OUT 8SOIC. Linear Regulator Controller IC Positive Fixed 1 Output 8-SOIC. PMIC - Voltage Regulators - Linear...
LT1575CS8-2.8#PBF
126 ₽
LT1575CS8-2.8#PBF
от 736 ₽
Hi-Tech Circuit Group
LT1575CS8-2.8#PBF
TradeElectronics
LT1575CS8-2.8
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Demo BoardsDC136A
Design ToolsLTspice Model
Discrete Pass Elementда
Экспортный контрольнет
Isupply12 мА
Max Junction Temp100 Deg
Количество выходов1
Выходной ток10 A
Выходное напряжениеAdj, 1.5, 2.8, 3.3, 5
Theta JA100В°C/W (S8), 130В°C/W (N8), 100В°C/W (S)
ТипNPN
Vin Max22 В
Vin Min5 В
Vout Min1.27 В
  • LT1575 UltraFast Linear Controller Makes Fast Transient Response Power Supplies &mdash AN69
    PDF, 224 Кб, Файл опубликован: 5 сен 1996
    AN69 describes considerations for linear regulators based on the LT1575 UltraFastTM Linear Regulator controller. The LT1575 drives an external MOSFET pass transistor as an overdriven source follower. This configuration results in an extremely high speed regulation loop which minimizes the need for output capacitors. Target applications are state of the art microprocessor core supplies which exhibit large, high speed load transients while having very tight supply voltage tolerance requirements. The application note shows numerous examples of circuit implementations and offers detailed discussions of design considerations.
  • A Monolithic Switching Regulator with 100ВµV Output Noise &mdash AN70
    PDF, 1.7 Мб, Язык: анг., Файл опубликован: 1 окт 1997
    This publication details circuitry and applications considerations for the LT1533 low noise switching regulator. Eleven DC/DC converter circuits are presented, some offering <100µV output noise in a 100MHz bandwidth. Tutorial sections detail low noise DC/DC design, measurement, probing and layout techniques, and magnetics selection.
  • Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84
    PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
    Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.
Design Notes
  • UltraFast Linear Regulator Eliminates All Bulk Tantalum and Electrolytic Output Capacitors &mdash DN157
    PDF, 92 Кб, Файл опубликован: 5 июн 1997
  • Very Low Dropout (VLDO) Linear Regulators Supply Low Voltage Outputs &mdash DN292
    PDF, 106 Кб, Файл опубликован: 2 авг 2002
  • Power Management > LDO Linear Regulators > Discrete Pass Element Linear Regulators (LDO)
LT1575CS8-2.8PBF, LT1575CS8-2.8 PBF, LT1575CS82.8#PBF, LT1575CS8 2.8#PBF
На английском языке: Datasheet Linear Technology LT1575CS8-2.8#PBF
Публикации по теме
