Datasheet Linear Technology LT1580IR-2.5#TRPBF — Даташит
Серия | LT1580 |
Модель | LT1580IR-2.5#TRPBF |
7A, регулятор с очень низким падением напряжения
Datasheet LT1580, LT1580-2.5
PDF, 245 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 16
7A, Very Low Dropout Regulator
![]() 8 предложений от 8 поставщиков , LDO Regulator Pos 2.5V 7A 8-Pin(7+Tab) DDPAK T/R | |||
LT1580IR-2.5#TRPBF Analog Devices | 302 ₽ | ||
LT1580IR-2.5#TRPBF Analog Devices | 468 ₽ | ||
LT1580IR-2.5 TRPBF Linear Technology | по запросу | ||
LT1580IR-2.5#TRPBF Linear Technology | по запросу |
Корпус | DDPAK-7 |
Код корпуса | R |
Индекс корпуса | 05-08-1462 |
Design Tools | LTspice Model |
Discrete Pass Element | нет |
Dropout Voltage | 0.54 В |
Экспортный контроль | нет |
Isupply | 10 мА |
Max Junction Temp | 150 Deg |
Количество выходов | 1 |
Выходной ток | 7 A |
Выходное напряжение | Adj, 2.5 |
Theta JA | 30В°C/W (Q), 50В°C/W (T) |
Тип | NPN |
Vin Max | 6 В |
Vin Min | 1.79 В |
Vout Max | 4.65 В |
Vout Min | 1.25 В |
- Linear Technology Magazine Circuit Collection, Volume II &mdash AN66PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.Выписка из документа
Design Notes
- LT1580 Fast Response Low Dropout Regulator Achieves 0.4 Dropout at 4 Amps &mdash DN119PDF, 100 Кб, Файл опубликован: 1 дек 1995Выписка из документа
- Dual Regulators Power PentiumВ® Processor or Upgrade CPU &mdash DN122PDF, 73 Кб, Файл опубликован: 1 фев 1996Выписка из документа
- Very Low Dropout (VLDO) Linear Regulators Supply Low Voltage Outputs &mdash DN292PDF, 106 Кб, Файл опубликован: 2 авг 2002Выписка из документа
Серия: LT1580 (15)
- Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
LT1580IR-2.5TRPBF, LT1580IR-2.5 TRPBF, LT1580IR2.5#TRPBF, LT1580IR 2.5#TRPBF
