Datasheet Linear Technology LT1580IT7-2.5#06PBF — Даташит
СерияLT1580
МодельLT1580IT7-2.5#06PBF
7A, регулятор с очень низким падением напряжения
Datasheet LT1580, LT1580-2.5
PDF, 245 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 16
7A, Very Low Dropout Regulator
LT1580IT7-2.5 06PBF
КорпусTO-220
Код корпусаT7
Индекс корпуса05-08-1422 (Std)
Design ToolsLTspice Model
Discrete Pass Elementнет
Dropout Voltage0.54 В
Экспортный контрольнет
Isupply10 мА
Max Junction Temp150 Deg
Количество выходов1
Выходной ток7 A
Выходное напряжениеAdj, 2.5
Theta JA30В°C/W (Q), 50В°C/W (T)
ТипNPN
Vin Max6 В
Vin Min1.79 В
Vout Max4.65 В
Vout Min1.25 В
  • Linear Technology Magazine Circuit Collection, Volume II &mdash AN66
    PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
    Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.
Design Notes
  • LT1580 Fast Response Low Dropout Regulator Achieves 0.4 Dropout at 4 Amps &mdash DN119
    PDF, 100 Кб, Файл опубликован: 1 дек 1995
  • Dual Regulators Power PentiumВ® Processor or Upgrade CPU &mdash DN122
    PDF, 73 Кб, Файл опубликован: 1 фев 1996
  • Very Low Dropout (VLDO) Linear Regulators Supply Low Voltage Outputs &mdash DN292
    PDF, 106 Кб, Файл опубликован: 2 авг 2002
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
LT1580IT7-2.506PBF, LT1580IT7-2.5 06PBF, LT1580IT72.5#06PBF, LT1580IT7 2.5#06PBF
На английском языке: Datasheet Linear Technology LT1580IT7-2.5#06PBF
Публикации по теме
