Datasheet Linear Technology LT1585CM#PBF — Даташит
СерияLT1585
МодельLT1585CM#PBF
Регулируемые и фиксированные положительные регуляторы с малым падением напряжения и быстрым откликом на 7A, 4.6A, 3A
Datasheet LT1584, LT1585, LT1587
PDF, 226 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 16
7A, 4.6A, 3A Low Dropout Fast Response Positive Regulators Adjustable and Fixed
52 предложений от 29 поставщиков
Чип стабилизации напряжения, LT1585 - 7A, 4.6A, 3A Low Dropout Fast Response Positive Regulators Adjustable and Fixed; Package: DD PAK; Pins:...
LT1585CM
147 ₽
LT1585CM-3.45#TRPBF
189 ₽
Элитан
LT1585CM-3.3
418 ₽
LT1585CM-3.3
Jamicon
КорпусDDPAK-3
Код корпусаM
Индекс корпуса05-08-1460
Demo BoardsDC065A-B
Design ToolsLTspice File
Discrete Pass Elementнет
Dropout Voltage1.1 В
Экспортный контрольнет
Isupply8 мА
Max Junction Temp150 Deg
Количество выходов1
Выходной ток4.6 A
Выходное напряжениеAdj, 1.5, 3.3,3.38, 3.45, 3.6
Theta JA30В°C/W (M), 50В°C/W (T)
ТипNPN
Vin Max7 В
Vin Min2.35 В
Vout Max5.5 В
Vout Min1.25 В
LT1584 LT1584 LT1587 LT1587
  • Linear Technology Magazine Circuit Collection, Volume II &mdash AN66
    PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
    Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.
Design Notes
  • Dual Regulators Power PentiumВ® Processor or Upgrade CPU &mdash DN122
    PDF, 73 Кб, Файл опубликован: 1 фев 1996
  • Fast Regulator Paces High Performance Processors &mdash DN87
    PDF, 85 Кб, Файл опубликован: 1 окт 1994
  • High Efficiency Power Sources for Pentium TM Processors &mdash DN90
    PDF, 85 Кб, Файл опубликован: 1 ноя 1994
  • 5V to 3.3V Circuit Collection &mdash DN91
    PDF, 74 Кб, Файл опубликован: 1 ноя 1994
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
LT1585CMPBF, LT1585CM PBF
На английском языке: Datasheet Linear Technology LT1585CM#PBF
Публикации по теме
