Datasheet Linear Technology LT1585CT#PBF — Даташит
Серия | LT1585 |
Модель | LT1585CT#PBF |
Регулируемые и фиксированные положительные регуляторы с малым падением напряжения и быстрым откликом на 7A, 4.6A, 3A
Datasheet LT1584, LT1585, LT1587
PDF, 226 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 16
7A, 4.6A, 3A Low Dropout Fast Response Positive Regulators Adjustable and Fixed
![]() 43 предложений от 26 поставщиков Чип стабилизации напряжения, LINEAR TECHNOLOGY LT1585CT-3.3#PBF Fixed LDO Voltage Regulator, 2.5V to 7V, 1.2V Dropout, 3.3Vout, 4.6Aout, TO-220-3 | |||
LT1585CT#PBF Analog Devices | 83 ₽ | ||
LT1585CT-1.5#PBF Linear Technology | 1 294 ₽ | ||
LT1585CT*36 | по запросу | ||
LT1585CT Linear Technology | по запросу |
Корпус | TO-220 |
Код корпуса | T |
Индекс корпуса | 05-08-1420 |
Demo Boards | DC065A-B |
Design Tools | LTspice File |
Discrete Pass Element | нет |
Dropout Voltage | 1.1 В |
Экспортный контроль | нет |
Isupply | 8 мА |
Max Junction Temp | 150 Deg |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 70 °C |
Выходной ток | 4.6 A |
Выходное напряжение | Adj, 1.5, 3.3,3.38, 3.45, 3.6 |
Theta JA | 30В°C/W (M), 50В°C/W (T) |
Тип | NPN |
Vin Max | 7 В |
Vin Min | 2.35 В |
Vout Max | 5.5 В |
Vout Min | 1.25 В |
- Linear Technology Magazine Circuit Collection, Volume II &mdash AN66PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.Выписка из документа
Design Notes
- Dual Regulators Power PentiumВ® Processor or Upgrade CPU &mdash DN122PDF, 73 Кб, Файл опубликован: 1 фев 1996Выписка из документа
- Fast Regulator Paces High Performance Processors &mdash DN87PDF, 85 Кб, Файл опубликован: 1 окт 1994Выписка из документа
- High Efficiency Power Sources for Pentium TM Processors &mdash DN90PDF, 85 Кб, Файл опубликован: 1 ноя 1994Выписка из документа
- 5V to 3.3V Circuit Collection &mdash DN91PDF, 74 Кб, Файл опубликован: 1 ноя 1994Выписка из документа
Серия: LT1585 (13)
- Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
LT1585CTPBF, LT1585CT PBF
