Datasheet Linear Technology LT1761ES5-3.3#TRMPBF — Даташит
СерияLT1761
МодельLT1761ES5-3.3#TRMPBF
100 мА, малошумные регуляторы малой мощности LDO в TSOT-23
Datasheet LT1761
PDF, 1.2 Мб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 22
100mA, Low Noise, LDO Micropower Regulators in TSOT-23
35 предложений от 16 поставщиков
Чип стабилизации напряжения, LINEAR TECHNOLOGY LT1761ES5-3.3#TRMPBF Fixed LDO Voltage Regulator, 1.8V to 20V, 300mV Dropout, 3.3Vout, 100mAout, TSOT-23-5
118 ₽
Элитан
LT1761ES5-3.3#TRMPBF Linear Technology Voltage Regulator
358 ₽
от 434 ₽
КорпусSOT-23
Код корпусаS5
Индекс корпуса05-08-1635
Demo BoardsDC330A
Design ToolsLTspice File
Discrete Pass Elementнет
Dropout Voltage0.3 В
Экспортный контрольнет
Основные особенностиShutdown
Ishutdown1 мкА
Isupply0.02 мА
Max Junction Temp125 Deg
Количество выходов1
Рабочий диапазон температурот 0 до 85 °C
Выходной ток0.1 A
Выходное напряжениеAdj, 1.2, 1.5, 1.8, 2, 2.5, 2.8, 3, 3.3, 5
PSRR65 дБ
RMS Noise20 µV
Theta JA250В°C/W (S5)
ТипPNP
Vin Max20 В
Vin Min1.8 В
Vout Max20 В
Vout Min1.22 В
  • Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83
    PDF, 542 Кб, Файл опубликован: 1 мар 2000
    In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.
Design Notes
  • Lowest Noise SOT-23 LDOs Have 20ВµA Quiescent Current, 20ВµVrms Noise &mdash DN220
    PDF, 114 Кб, Файл опубликован: 1 дек 1999
  • Isolated RS485 Transceiver Breaks Ground Loops &mdash DN228
    PDF, 992 Кб, Файл опубликован: 2 апр 2001
  • Ultralow Noise Switching Power Supplies Simplify EMI Compliance &mdash DN316
    PDF, 94 Кб, Файл опубликован: 2 июл 2003
  • Tiny Versatile Buck Regulators Operate from 3.6V to 36V Input &mdash DN367
    PDF, 80 Кб, Файл опубликован: 10 май 2005
Статьи
  • A Simple Solution to Low Noise, Isolated Power Conversion &mdash LT Journal
    PDF, 181 Кб, Файл опубликован: 1 ноя 2002
  • Micropower LDO Has the Lowest Noise and Quiescent Current in SOT-23 &mdash LT Journal
    PDF, 312 Кб, Файл опубликован: 1 июн 1999
  • Dual Regulators Offer Flexibility with Independent Shutdown Control and Adjustable Start-Up Timing &mdash LT Journal
    PDF, 210 Кб, Файл опубликован: 1 май 2004
Серия: LT1761 (79)
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO) | Extended Temperature (H & MP) Linear Regulators
LT1761ES5-3.3TRMPBF, LT1761ES5-3.3 TRMPBF, LT1761ES53.3#TRMPBF, LT1761ES5 3.3#TRMPBF
На английском языке: Datasheet Linear Technology LT1761ES5-3.3#TRMPBF
Публикации по теме
