Datasheet Linear Technology LT1761IS5-3#TRPBF — Даташит
Серия | LT1761 |
Модель | LT1761IS5-3#TRPBF |
100 мА, малошумные регуляторы малой мощности LDO в TSOT-23
Datasheet LT1761
PDF, 1.2 Мб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 22
100mA, Low Noise, LDO Micropower Regulators in TSOT-23
![]() 33 предложений от 18 поставщиков Интегральные микросхемы Силовые чипы — регуляторы напряжения — линейные | |||
LT1761IS5-3#TRPBF | 124 ₽ | ||
LT1761IS5-3.3#TRPBF Analog Devices | от 176 ₽ | ||
LT1761IS5-3#TRPBF Linear Technology | от 333 ₽ | ||
LT1761IS5-3 TRPBF Linear Technology | по запросу |
Корпус | SOT-23 |
Код корпуса | S5 |
Индекс корпуса | 05-08-1635 |
Demo Boards | DC330A |
Design Tools | LTspice File |
Discrete Pass Element | нет |
Dropout Voltage | 0.3 В |
Экспортный контроль | нет |
Основные особенности | Shutdown |
Ishutdown | 1 мкА |
Isupply | 0.02 мА |
Max Junction Temp | 125 Deg |
Количество выходов | 1 |
Выходной ток | 0.1 A |
Выходное напряжение | Adj, 1.2, 1.5, 1.8, 2, 2.5, 2.8, 3, 3.3, 5 |
PSRR | 65 дБ |
RMS Noise | 20 µV |
Theta JA | 250В°C/W (S5) |
Тип | PNP |
Vin Max | 20 В |
Vin Min | 1.8 В |
Vout Max | 20 В |
Vout Min | 1.22 В |
- Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83PDF, 542 Кб, Файл опубликован: 1 мар 2000
In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.Выписка из документа
Design Notes
- Lowest Noise SOT-23 LDOs Have 20ВµA Quiescent Current, 20ВµVrms Noise &mdash DN220PDF, 114 Кб, Файл опубликован: 1 дек 1999Выписка из документа
- Isolated RS485 Transceiver Breaks Ground Loops &mdash DN228PDF, 992 Кб, Файл опубликован: 2 апр 2001Выписка из документа
- Ultralow Noise Switching Power Supplies Simplify EMI Compliance &mdash DN316PDF, 94 Кб, Файл опубликован: 2 июл 2003Выписка из документа
- Tiny Versatile Buck Regulators Operate from 3.6V to 36V Input &mdash DN367PDF, 80 Кб, Файл опубликован: 10 май 2005Выписка из документа
Статьи
- A Simple Solution to Low Noise, Isolated Power Conversion &mdash LT JournalPDF, 181 Кб, Файл опубликован: 1 ноя 2002Выписка из документа
- Micropower LDO Has the Lowest Noise and Quiescent Current in SOT-23 &mdash LT JournalPDF, 312 Кб, Файл опубликован: 1 июн 1999Выписка из документа
- Dual Regulators Offer Flexibility with Independent Shutdown Control and Adjustable Start-Up Timing &mdash LT JournalPDF, 210 Кб, Файл опубликован: 1 май 2004Выписка из документа
Серия: LT1761 (79)
- LT1761ES5-1.2#PBF LT1761ES5-1.2#TRMPBF LT1761ES5-1.2#TRPBF LT1761ES5-1.5#PBF LT1761ES5-1.5#TRMPBF LT1761ES5-1.5#TRPBF LT1761ES5-1.8#PBF LT1761ES5-1.8#TRMPBF LT1761ES5-1.8#TRPBF LT1761ES5-2#PBF LT1761ES5-2#TRMPBF LT1761ES5-2#TRPBF LT1761ES5-2.5#PBF LT1761ES5-2.5#TRMPBF LT1761ES5-2.5#TRPBF LT1761ES5-2.8#PBF LT1761ES5-2.8#TRMPBF LT1761ES5-2.8#TRPBF LT1761ES5-3#PBF LT1761ES5-3#TRMPBF LT1761ES5-3#TRPBF LT1761ES5-3.3#PBF LT1761ES5-3.3#TRMPBF LT1761ES5-3.3#TRPBF LT1761ES5-5#PBF LT1761ES5-5#TRMPBF LT1761ES5-5#TRPBF LT1761ES5-BYP#PBF LT1761ES5-BYP#TRMPBF LT1761ES5-BYP#TRPBF LT1761ES5-SD#PBF LT1761ES5-SD#TRMPBF LT1761ES5-SD#TRPBF LT1761IS5-1.2#PBF LT1761IS5-1.2#TRMPBF LT1761IS5-1.2#TRPBF LT1761IS5-1.5#PBF LT1761IS5-1.5#TRMPBF LT1761IS5-1.5#TRPBF LT1761IS5-1.8#PBF LT1761IS5-1.8#TRMPBF LT1761IS5-1.8#TRPBF LT1761IS5-2#PBF LT1761IS5-2#TRMPBF LT1761IS5-2#TRPBF LT1761IS5-2.5#PBF LT1761IS5-2.5#TRMPBF LT1761IS5-2.5#TRPBF LT1761IS5-2.8#PBF LT1761IS5-2.8#TRMPBF LT1761IS5-2.8#TRPBF LT1761IS5-3#PBF LT1761IS5-3#TRMPBF LT1761IS5-3#TRPBF LT1761IS5-3.3#PBF LT1761IS5-3.3#TRMPBF LT1761IS5-3.3#TRPBF LT1761IS5-5#PBF LT1761IS5-5#TRMPBF LT1761IS5-5#TRPBF LT1761IS5-BYP#PBF LT1761IS5-BYP#TRMPBF LT1761IS5-BYP#TRPBF LT1761IS5-SD#PBF LT1761IS5-SD#TRMPBF LT1761IS5-SD#TRPBF LT1761MPS5-1.8#TRMPBF LT1761MPS5-1.8#TRPBF LT1761MPS5-3.3 LT1761MPS5-3.3#PBF LT1761MPS5-3.3#TR LT1761MPS5-3.3#TRM LT1761MPS5-3.3#TRMPBF LT1761MPS5-3.3#TRPBF LT1761MPS5-5#PBF LT1761MPS5-5#TR LT1761MPS5-5#TRM LT1761MPS5-5#TRMPBF LT1761MPS5-5#TRPBF
- Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO) | Extended Temperature (H & MP) Linear Regulators
LT1761IS5-3TRPBF, LT1761IS5-3 TRPBF, LT1761IS53#TRPBF, LT1761IS5 3#TRPBF
