Datasheet Linear Technology LT1763IS8#TRPBF — Даташит
Серия | LT1763 |
Модель | LT1763IS8#TRPBF |
Малошумящие регуляторы малой мощности, LDO, 500 мА
Datasheet LT1763
PDF, 1.2 Мб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 22
500mA, Low Noise, LDO Micropower Regulators
![]() 29 предложений от 15 поставщиков Интегральные микросхемы Силовые чипы — регуляторы напряжения — линейные | |||
LT1763IS8-3#TRPBF | 262 ₽ | ||
LT1763IS8#TRPBF | от 738 ₽ | ||
LT1763IS8-5#TRPBF Analog Devices | по запросу | ||
LT1763IS8#TRPBF Linear Technology | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Demo Boards | DC368A |
Design Tools | LTspice File |
Discrete Pass Element | нет |
Dropout Voltage | 0.3 В |
Экспортный контроль | нет |
Основные особенности | Shutdown |
Ishutdown | 1 мкА |
Isupply | 0.03 мА |
Max Junction Temp | 150 Deg |
Количество выходов | 1 |
Выходной ток | 0.5 A |
Выходное напряжение | Adj,1.5, 1.8, 2.5, 3, 3.3, 5 |
PSRR | 65 дБ |
RMS Noise | 20 µV |
Theta JA | 40В°C/W (DE), 70В°C/W (S8) |
Тип | PNP |
Vin Max | 20 В |
Vin Min | 1.8 В |
Vout Max | 20 В |
Vout Min | 1.22 В |
- Minimizing Switching Regulator Residue in Linear Regulator Outputs &mdash AN101PDF, 358 Кб, Язык: анг., Файл опубликован: 16 июл 2005, Страниц: 12
Application Note 101. Linear regulators are commonly employed to post-regulate switching regulator outputs. Benefits include improved stability, accuracy, transient response and lowered output impedance. Ideally, these performance gains would be accompanied by markedly reduced switching regulator generated ripple and spikes. In practice, all linear regulators encounter some difficulty with ripple and spikes, particularly as frequency rises. This publication explains the causes of linear regulators' dynamic limitations and presents board level techniques for improving ripple and spike rejection. A hardware based ripple/spike simulator is presented, enabling rapid breadboard testing under various conditions. Three appendices review ferrite beads, inductor based filters and probing practice for wideband, sub-millivolt signals.Выписка из документа - Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83PDF, 542 Кб, Файл опубликован: 1 мар 2000
In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.Выписка из документа
Design Notes
- Lowest Noise SOT-23 LDOs Have 20ВµA Quiescent Current, 20ВµVrms Noise &mdash DN220PDF, 114 Кб, Файл опубликован: 1 дек 1999Выписка из документа
Статьи
- Dual Regulators Offer Flexibility with Independent Shutdown Control and Adjustable Start-Up Timing &mdash LT JournalPDF, 210 Кб, Файл опубликован: 1 май 2004Выписка из документа
Серия: LT1763 (83)
- LT1763CDE#PBF LT1763CDE#TRPBF LT1763CDE-1.5#PBF LT1763CDE-1.5#TRPBF LT1763CDE-1.8#PBF LT1763CDE-1.8#TRPBF LT1763CDE-2.5#PBF LT1763CDE-2.5#TRPBF LT1763CDE-3#PBF LT1763CDE-3#TRPBF LT1763CDE-3.3#PBF LT1763CDE-3.3#TRPBF LT1763CDE-5#PBF LT1763CDE-5#TRPBF LT1763CS8#PBF LT1763CS8#TRPBF LT1763CS8-1.5#PBF LT1763CS8-1.5#TRPBF LT1763CS8-1.8#PBF LT1763CS8-1.8#TRPBF LT1763CS8-2.5#PBF LT1763CS8-2.5#TRPBF LT1763CS8-3#PBF LT1763CS8-3#TRPBF LT1763CS8-3.3#PBF LT1763CS8-3.3#TRPBF LT1763CS8-5#PBF LT1763CS8-5#TRPBF LT1763IDE#PBF LT1763IDE#TRPBF LT1763IDE-1.5#PBF LT1763IDE-1.5#TRPBF LT1763IDE-1.8#PBF LT1763IDE-1.8#TRPBF LT1763IDE-2.5#PBF LT1763IDE-2.5#TRPBF LT1763IDE-3#PBF LT1763IDE-3#TRPBF LT1763IDE-3.3#PBF LT1763IDE-3.3#TRPBF LT1763IDE-5#PBF LT1763IDE-5#TRPBF LT1763IS8#PBF LT1763IS8#TRPBF LT1763IS8-1.5#PBF LT1763IS8-1.5#TRPBF LT1763IS8-1.8#PBF LT1763IS8-1.8#TRPBF LT1763IS8-2.5#PBF LT1763IS8-2.5#TRPBF LT1763IS8-3#PBF LT1763IS8-3#TRPBF LT1763IS8-3.3#PBF LT1763IS8-3.3#TRPBF LT1763IS8-5#PBF LT1763IS8-5#TRPBF LT1763MPDE LT1763MPDE#PBF LT1763MPDE#TR LT1763MPDE#TRPBF LT1763MPDE-1.5 LT1763MPDE-1.5#PBF LT1763MPDE-1.5#TRPBF LT1763MPDE-1.8#PBF LT1763MPDE-1.8#TRPBF LT1763MPDE-2.5#PBF LT1763MPDE-2.5#TRPBF LT1763MPDE-3#PBF LT1763MPDE-3#TRPBF LT1763MPDE-3.3 LT1763MPDE-3.3#PBF LT1763MPDE-3.3#TR LT1763MPDE-3.3#TRPBF LT1763MPDE-5#PBF LT1763MPDE-5#TRPBF LT1763MPS8 LT1763MPS8#PBF LT1763MPS8#TR LT1763MPS8#TRPBF LT1763MPS8-2.5#PBF LT1763MPS8-2.5#TRPBF LT1763MPS8-5#PBF LT1763MPS8-5#TRPBF
- Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO) | Extended Temperature (H & MP) Linear Regulators
LT1763IS8TRPBF, LT1763IS8 TRPBF
