Datasheet Linear Technology LT1962EMS8-1.5#PBF — Даташит
Серия | LT1962 |
Модель | LT1962EMS8-1.5#PBF |
Малошумящие малошумящие регуляторы LDO, 300 мА
Datasheet LT1962
PDF, 481 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 18
300mA, Low Noise, Micropower LDO Regulators
![]() 43 предложений от 21 поставщиков Чип стабилизации напряжения, LINEAR TECHNOLOGY LT1962EMS8-1.5#PBF Fixed LDO Voltage Regulator, 1.8V to 20V, 270mV Dropout, 1.5Vout, 300mAout, MSOP-8 | |||
LT1962EMS8-1.5#TRPBF Analog Devices | от 76 ₽ | ||
LT1962EMS8-1.5#TR Linear Technology | 141 ₽ | ||
LT1962EMS8-1.5TR | по запросу | ||
LT1962EMS81.5#TR | по запросу |
Корпус | MS-8 |
Код корпуса | MS8 |
Индекс корпуса | 05-08-1660 |
Demo Boards | DC339A-B |
Design Tools | LTspice File |
Discrete Pass Element | нет |
Dropout Voltage | 0.27 В |
Экспортный контроль | нет |
Основные особенности | Shutdown |
Ishutdown | 1 мкА |
Isupply | 0.03 мА |
Max Junction Temp | 150 Deg |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 85 °C |
Выходной ток | 0.3 A |
Выходное напряжение | Adj,1.5, 1.8, 2.5, 3, 3.3, 5 |
PSRR | 65 дБ |
RMS Noise | 20 µV |
Theta JA | 125В°C/W (MS8) |
Тип | PNP |
Vin Max | 20 В |
Vin Min | 1.8 В |
Vout Max | 20 В |
Vout Min | 1.22 В |
- Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83PDF, 542 Кб, Файл опубликован: 1 мар 2000
In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.Выписка из документа
Серия: LT1962 (16)
- Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
LT1962EMS8-1.5PBF, LT1962EMS8-1.5 PBF, LT1962EMS81.5#PBF, LT1962EMS8 1.5#PBF
