Datasheet Linear Technology LT1962IMS8#TRPBF — Даташит
СерияLT1962
МодельLT1962IMS8#TRPBF
Малошумящие малошумящие регуляторы LDO, 300 мА
Datasheet LT1962
PDF, 481 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 18
300mA, Low Noise, Micropower LDO Regulators
27 предложений от 11 поставщиков
Микросхемы управления электропитанием - Стабилизаторы напряжения - Линейные
LT1962IMS8#TRPBF
92 ₽
LT1962IMS8#TRPBF
154 ₽
LT1962IMS8#TRPBF
189 ₽
LT1962IMS8#TRPBF
417 ₽
КорпусMS-8
Код корпусаMS8
Индекс корпуса05-08-1660
Demo BoardsDC339A-B
Design ToolsLTspice File
Discrete Pass Elementнет
Dropout Voltage0.27 В
Экспортный контрольнет
Основные особенностиShutdown
Ishutdown1 мкА
Isupply0.03 мА
Max Junction Temp150 Deg
Количество выходов1
Выходной ток0.3 A
Выходное напряжениеAdj,1.5, 1.8, 2.5, 3, 3.3, 5
PSRR65 дБ
RMS Noise20 µV
Theta JA125В°C/W (MS8)
ТипPNP
Vin Max20 В
Vin Min1.8 В
Vout Max20 В
Vout Min1.22 В
  • Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83
    PDF, 542 Кб, Файл опубликован: 1 мар 2000
    In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
LT1962IMS8TRPBF, LT1962IMS8 TRPBF
На английском языке: Datasheet Linear Technology LT1962IMS8#TRPBF
Публикации по теме
