Datasheet Linear Technology LT1963AEST-2.5#TRPBF — Даташит
СерияLT1963A
МодельLT1963AEST-2.5#TRPBF
1,5 А, малошумящие стабилизаторы LDO с быстрым переходным откликом
Datasheet LT1963A
PDF, 552 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 28
1.5A, Low Noise, Fast Transient Response LDO Regulators
36 предложений от 17 поставщиков
Интегральные микросхемы Силовые чипы — регуляторы напряжения — линейные
160 ₽
204 ₽
от 638 ₽
LT1963AEST-2.5 TRPBF
КорпусSOT-223
Код корпусаST
Индекс корпуса05-08-1630
Design ToolsLTspice File
Discrete Pass Elementнет
Dropout Voltage0.34 В
Экспортный контрольнет
Основные особенностиShutdown
Ishutdown.01 мкА
Isupply1 мА
Max Junction Temp150 Deg
Количество выходов1
Рабочий диапазон температурот 0 до 85 °C
Выходной ток1.5 A
Выходное напряжениеAdj, 1.5, 1.8, 2.5, 3.3
PSRR63 дБ
RMS Noise40 µV
Theta JA30В°C/W (Q), 50В°C/W (T), 38В°C/W (FE), 50В°C/W (ST), 70В°C/W (S8)
ТипPNP
Vin Max20 В
Vin Min2.1 В
Vout Max20 В
Vout Min1.21 В
LT1963A Series
  • Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83
    PDF, 542 Кб, Файл опубликован: 1 мар 2000
    In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO) | Extended Temperature (H & MP) Linear Regulators
LT1963AEST-2.5TRPBF, LT1963AEST-2.5 TRPBF, LT1963AEST2.5#TRPBF, LT1963AEST 2.5#TRPBF
На английском языке: Datasheet Linear Technology LT1963AEST-2.5#TRPBF
Публикации по теме
