Datasheet Linear Technology LT1963AET-1.5#06PBF — Даташит
| Серия | LT1963A |
| Модель | LT1963AET-1.5#06PBF |
1,5 А, малошумящие стабилизаторы LDO с быстрым переходным откликом
Datasheet LT1963A
PDF, 552 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 28
1.5A, Low Noise, Fast Transient Response LDO Regulators
| LT1963AET-1.5 06PBF Linear Technology | по запросу | ||
| Корпус | TO-220 |
| Код корпуса | T |
| Индекс корпуса | 05-08-1421 (Flow 06) |
| Design Tools | LTspice File |
| Discrete Pass Element | нет |
| Dropout Voltage | 0.34 В |
| Экспортный контроль | нет |
| Основные особенности | Shutdown |
| Ishutdown | .01 мкА |
| Isupply | 1 мА |
| Max Junction Temp | 150 Deg |
| Количество выходов | 1 |
| Рабочий диапазон температур | от 0 до 85 °C |
| Выходной ток | 1.5 A |
| Выходное напряжение | Adj, 1.5, 1.8, 2.5, 3.3 |
| PSRR | 63 дБ |
| RMS Noise | 40 µV |
| Theta JA | 30В°C/W (Q), 50В°C/W (T), 38В°C/W (FE), 50В°C/W (ST), 70В°C/W (S8) |
| Тип | PNP |
| Vin Max | 20 В |
| Vin Min | 2.1 В |
| Vout Max | 20 В |
| Vout Min | 1.21 В |
- Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83PDF, 542 Кб, Файл опубликован: 1 мар 2000
In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.Выписка из документа
Серия: LT1963A (65)
- LT1963AEFE#PBF LT1963AEFE#TRPBF LT1963AEFE-1.5#PBF LT1963AEFE-1.5#TRPBF LT1963AEFE-1.8#PBF LT1963AEFE-1.8#TRPBF LT1963AEFE-2.5#PBF LT1963AEFE-2.5#TRPBF LT1963AEFE-3.3#PBF LT1963AEFE-3.3#TRPBF LT1963AEQ#PBF LT1963AEQ#TRPBF LT1963AEQ-1.5#PBF LT1963AEQ-1.5#TRPBF LT1963AEQ-1.8#PBF LT1963AEQ-1.8#TRPBF LT1963AEQ-2.5#PBF LT1963AEQ-2.5#TRPBF LT1963AEQ-3.3#PBF LT1963AEQ-3.3#TRPBF LT1963AES8#PBF LT1963AES8#TRPBF LT1963AES8-1.5#PBF LT1963AES8-1.5#TRPBF LT1963AES8-1.8#PBF LT1963AES8-1.8#TRPBF LT1963AES8-2.5#PBF LT1963AES8-2.5#TRPBF LT1963AES8-3.3#PBF LT1963AES8-3.3#TRPBF LT1963AEST-1.5#PBF LT1963AEST-1.5#TRPBF LT1963AEST-1.8#PBF LT1963AEST-1.8#TRPBF LT1963AEST-2.5#PBF LT1963AEST-2.5#TRPBF LT1963AEST-3.3#PBF LT1963AEST-3.3#TRPBF LT1963AET#06PBF LT1963AET#PBF LT1963AET-1.5#06PBF LT1963AET-1.5#PBF LT1963AET-1.8#06PBF LT1963AET-1.8#30PBF LT1963AET-1.8#PBF LT1963AET-2.5#06PBF LT1963AET-2.5#30PBF LT1963AET-2.5#PBF LT1963AET-3.3#06PBF LT1963AET-3.3#30PBF LT1963AET-3.3#PBF LT1963AIFE#PBF LT1963AIFE#TRPBF LT1963AIQ#PBF LT1963AIQ#TRPBF LT1963AIS8#PBF LT1963AIS8#TRPBF LT1963AIT#PBF LT1963AMPQ LT1963AMPQ#PBF LT1963AMPQ#TR LT1963AMPQ#TRPBF LT1963AMPS8 LT1963AMPS8#PBF LT1963AMPS8#TR
- Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO) | Extended Temperature (H & MP) Linear Regulators
LT1963AET-1.506PBF, LT1963AET-1.5 06PBF, LT1963AET1.5#06PBF, LT1963AET 1.5#06PBF
