Datasheet Linear Technology LT3045 — Даташит
СерияLT3045
Линейный стабилизатор PSRR со сверхнизким уровнем шума, 20 В, 500 мА
LT3045 - 20V, 500mA, Ultralow Noise, Ultrahigh PSRR Linear Regulator
PDF, 3.0 Мб, Версия: A, Файл закачен: 20 окт 2017
LT3045EDD#PBFLT3045EDD#TRPBFLT3045EMSE#PBFLT3045EMSE#TRPBFLT3045HDD#PBFLT3045HDD#TRPBFLT3045IDD#PBFLT3045IDD#TRPBFLT3045IMSE#PBFLT3045IMSE#TRPBF
N12345678910
Корпус3x3 DFN-10
Габаритный чертеж корпуса
3x3 DFN-10
MS-12E
MS-12E
3x3 DFN-10
3x3 DFN-10
3x3 DFN-10
3x3 DFN-10
MS-12E
MS-12E
Код корпусаDDDDMSEMSEDDDDDDDDMSEMSE
Индекс корпуса05-08-169905-08-169905-08-166605-08-166605-08-169905-08-169905-08-169905-08-169905-08-166605-08-1666
Количество выводов10101212101010101212
Parameters / ModelsLT3045EDD#PBFLT3045EDD#TRPBFLT3045EMSE#PBFLT3045EMSE#TRPBFLT3045HDD#PBFLT3045HDD#TRPBFLT3045IDD#PBFLT3045IDD#TRPBFLT3045IMSE#PBFLT3045IMSE#TRPBF
Demo BoardsDC2491ADC2491ADC2491ADC2491ADC2491ADC2491ADC2491ADC2491ADC2491ADC2491A
Design ToolsLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice File
Discrete Pass Elementнетнетнетнетнетнетнетнетнетнет
Dropout Voltage, В0.260.260.260.260.260.260.260.260.260.26
Экспортный контрольнетнетнетнетнетнетнетнетнетнет
Основные особенностиUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, ShutdownUltralow Noise, Ultrahigh PSRR, Current Source Reference, Output Current Monitor, Power Good, Shutdown
Ishutdown, мкА0.30.30.30.30.30.30.30.30.30.3
Isupply, мА2.42.42.42.42.42.42.42.42.42.4
LDO Output Current, A0.50.50.50.50.50.50.50.50.50.5
Max Junction Temp, Deg150150150150150150150150150150
Количество выходов1111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A0.50.50.50.50.50.50.50.50.50.5
Выходное напряжениеAdjAdjAdjAdjAdjAdjAdjAdjAdjAdj
PSRR, дБ76767676767676767676
RMS Noise, µV0.80.80.80.80.80.80.80.80.80.8
Theta JA34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)34В°C/W (DD), 33В°C/W (MSE)
ТипPNPPNPPNPPNPPNPPNPPNPPNPPNPPNP
Vin Max, В20202020202020202020
Vin Min, В1.81.81.81.81.81.81.81.81.81.8
Vout Max, В15151515151515151515
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Measuring 2nV/в€љHz Noise and 120dB Supply Rejection on Linear Regulators &mdash AN159
    PDF, 1.1 Мб, Файл опубликован: 2 фев 2016
Статьи
  • Industry's First 0.8µVRMS Noise LDO Has 79dB Power Supply Rejection Ratio at 1MHz &mdash LT Journal
    PDF, 1.1 Мб, Файл опубликован: 7 апр 2015
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
На английском языке: Datasheet Linear Technology LT3045
Политика конфиденциальности
