Оптопары и оптореле Megawin
Datasheet Linear Technology LT1071CT#PBF — Даташит
СерияLT1071
МодельLT1071CT#PBF
Высокоэффективные импульсные регуляторы 5А и 2,5А
Datasheet LT1070, LT1071
PDF, 218 Кб, Версия: E, Файл закачен: 3 сен 2017, Страниц: 12
5A and 2.5A High Efficiency Switching Regulators
43 предложений от 25 поставщиков
727GS
LT1071CT#PBF
от 246 ₽
LT1071CT#33
TradeElectronics
LT1071CT/LTC
LT1071CT#PBF
КорпусTO-220
Код корпусаT
Индекс корпуса05-08-1421 (Std)
Design ToolsLTspice File
Экспортный контрольнет
Тактовая частота40 kHz
Ishutdown100 мкА
Isupply6 мА
Monolithicда
Количество выходов1
Switch Current2.5 A
Synchronousнет
TopologyBoost, Flyback, Sepic
Vin Max40 В
Vin Min3 В
Vin Min Startup3 В
Vout Max40 В
Vout Min1.244 В
Vswitch Max65 В
LT1070 LT1070HV LT1071HV
  • LT1070 Design Manual &mdash AN19
    PDF, 656 Кб, Язык: анг., Файл опубликован: 1 июн 1986, Страниц: 80
    Application Note 19. This design manual is an extensive discussion of all standard switching configurations for the LT1070; including buck, boost, flyback, forward, inverting and "Cuk." The manual includes comprehensive information on the LT1070, the external components used with it, and complete formulas for calculating component values.
  • Switching Regulators for Poets: A Gentle Guide for the Trepidatious &mdash AN25
    PDF, 359 Кб, Файл опубликован: 2 сен 1987
    Subtitled "A Gentle Guide for the Trepidatious," this is a tutorial on switching regulator design. The text assumes no switching regulator design experience, contains no equations, and requires no inductor construction to build the circuits described. Designs detailed include flyback, isolated telecom, off-line, and others. Appended sections cover component considerations, measurement techniques and steps involved in developing a working circuit.
  • Some Thoughts on DC-DC Converters &mdash AN29
    PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
    This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.
  • Switching Regulator Circuit Collection &mdash AN30
    PDF, 606 Кб, Файл опубликован: 1 фев 1989
    Switching regulators are of universal interest. Linear Technology has made a major effort to address this topic. A catalog of circuits has been compiled so that a design engineer can swiftly determine which converter type is best. This catalog serves as a visual index to be browsed through for a specific or general interest.
  • Linear Circuits for Digital Systems &mdash AN31
    PDF, 1.5 Мб, Файл опубликован: 2 фев 1989
    Subtitled "Some Affable Analogs for Digital Devotees," discusses a number of analog circuits useful in predominantly digital systems. VPP generators for flash memories receive extensive treatment. Other examples include a current loop transmitter, dropout detectors, power management circuits, and clocks.
  • Efficiency and Power Characteristics of Switching Regulator Circuits &mdash AN46
    PDF, 2.6 Мб, Файл опубликован: 1 ноя 1991
    Efficiency varies for different DC/DC converters. This application note compares the efficiency characteristics of some of the more popular types. Step-up, step-down, flyback, negative-to-positive, and positive-to-negative are shown. Appended sections discuss how to select the proper aluminum electrolytic capacitor and explain power switch and output diode loss calculations.
Design Notes
  • A Battery Powered Lap Top Computer Power Supply &mdash DN18
    PDF, 90 Кб, Файл опубликован: 1 дек 1988
Серия: LT1071 (4)
  • Power Management > Switching Regulator > SEPIC Regulators
  • Power Management > Switching Regulator > Step-Up (Boost) Regulators > Internal Power Switch Boost
LT1071CTPBF, LT1071CT PBF
На английском языке: Datasheet Linear Technology LT1071CT#PBF
