Datasheet Linear Technology LT1076CT#30PBF — Даташит
СерияLT1076
МодельLT1076CT#30PBF
Понижающий импульсный регулятор
Datasheet LT1074, LT1076
PDF, 189 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 16
Step-Down Switching Regulator
26 предложений от 14 поставщиков
LT1076CT#30PBF
262 ₽
LT1076CT#30PBF
от 640 ₽
LT1076CT#30PBF
1 132 ₽
LT1076CT#30PBF
КорпусTO-220
Код корпусаT
Индекс корпуса05-08-1421 (Std)
АрхитектураConstant Frequency Current Mode
Design ToolsLTspice File
Экспортный контрольнет
Тактовая частота100 kHz
Integrated Inductorнет
Ishutdown140 мкА
Isupply8.5 мА
Max Phases1
Monolithicда
Количество выходов1
Выходной ток1.6 A
Polyphaseнет
Switch Current2.6 A
Synchronousнет
TopologyBuck, Inverting
Vin Max45 В
Vin Min7.3 В
Vout Max35 В
Vout Maximum35V
Vout Min2.21 В
Vswitch Max65 В
LT1074 LT1074 LT1074HV LT1076HV
  • LT1074/LT1076 Design Manual &mdash AN44
    PDF, 477 Кб, Файл опубликован: 1 сен 1991
    This note discusses the use of the LT1074 and LT1076 high efficiency switching regulators. These regulators are specifically designed for ease of use. This application note is intended to eliminate the most common errors that customers make when using switching regulators as well as offering insight into the inner workings of switching designs. There is an entirely new treatment of inductor design based upon simple mathematical formulas that yield direct results. There are extensive tutorial sections devoted to the care and feeding of the Positive Step- Down (Buck) Converter, the Tapped Inductor Buck Converter, the Positive-to-Negative Converter and the Negative Boost Converter. Additionally, many troubleshooting hints are included as well as oscilloscope techniques, soft-start architectures, and micropower shutdown and EMI suppression methods.
Design Notes
  • High Performance Frequency Compensation Gives DC-to-DC Converter 75Вµs Response With High Stability &mdash DN53
    PDF, 81 Кб, Файл опубликован: 1 окт 1991
  • Low Parts Count DC/DC Converter Circuit With 3.3V and 5V Outputs &mdash DN69
    PDF, 69 Кб, Файл опубликован: 1 апр 1993
  • Power Management > Switching Regulator > Inverting Regulators
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck | High Input Voltage Buck
LT1076CT30PBF, LT1076CT 30PBF
На английском языке: Datasheet Linear Technology LT1076CT#30PBF
