Datasheet Linear Technology LT1374IS8#TRPBF — Даташит
| Серия | LT1374 |
| Модель | LT1374IS8#TRPBF |
Понижающий импульсный стабилизатор, 4,5 А, 500 кГц
Datasheet LT1374
PDF, 720 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 32
4.5A, 500kHz Step-Down Switching Regulator
Купить LT1374IS8#TRPBF на РадиоЛоцман.Цены — от 229 до 549 ₽14 предложений от 14 поставщиков IC REG BUCK SEPIC ADJ 4.5A 8SOIC. Buck, SEPIC Switching Regulator IC Positive Adjustable 2.42V 1 Output 4.5A (Switch) 8-SOIC (0.154',... | |||
| LT1374IS8#TRPBF Analog Devices | 356 ₽ | ||
| LT1374IS8#TRPBF Analog Devices | 510 ₽ | ||
| LT1374IS8#TRPBF Linear Technology | по запросу | ||
| LT1374IS8-5#TRPBF Linear Technology | по запросу | ||
| Корпус | SO-8 |
| Код корпуса | S8 |
| Индекс корпуса | 05-08-1610 (S8) |
| Архитектура | Constant Frequency Current Mode |
| Demo Boards | DC187A-A,DC187A-B,DC188A-A,DC188A-B,DC474A |
| Design Tools | LTspice File |
| Экспортный контроль | нет |
| Основные особенности | External Synchronization |
| Тактовая частота | 500 kHz |
| Frequency Sync Range | 580kHz - 1MHz |
| Integrated Inductor | нет |
| Ishutdown | 20 мкА |
| Isupply | 2.5 мА |
| Max Phases | 1 |
| Monolithic | да |
| Количество выходов | 1 |
| Выходной ток | 3.6 A |
| Polyphase | нет |
| Switch Current | 6 A |
| Synchronous | нет |
| Topology | Buck |
| Vin Max | 25 В |
| Vin Min | 5 В |
| Vout Max | 21.5 В |
| Vout Maximum | .86VIN |
| Vout Min | 2.42 В |
| Vswitch Max | 38 В |
- Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.Выписка из документа
Design Notes
- A High Efficiency 500kHz, 4.5A Step-Down Converter in an SO-8 Package &mdash DN181PDF, 80 Кб, Файл опубликован: 2 май 1998Выписка из документа
Серия: LT1374 (36)
- LT1374CFE#PBF LT1374CFE#TRPBF LT1374CR#PBF LT1374CR#TRPBF LT1374CR-5#PBF LT1374CR-5#TRPBF LT1374CR-5SYNC#PBF LT1374CR-5Sync#TRPBF LT1374CR-SYNC#PBF LT1374CR-Sync#TRPBF LT1374CS8#PBF LT1374CS8#TRPBF LT1374CS8-5#PBF LT1374CS8-5#TRPBF LT1374CS8-5SYNC#PBF LT1374CS8-5Sync#TRPBF LT1374CS8-SYNC#PBF LT1374CS8-Sync#TRPBF LT1374CT7#PBF LT1374CT7-5#PBF LT1374IFE#PBF LT1374IFE#TRPBF LT1374IR#PBF LT1374IR#TRPBF LT1374IR-5#PBF LT1374IR-5#TRPBF LT1374IR-5SYNC#PBF LT1374IR-SYNC#PBF LT1374IS8#PBF LT1374IS8#TRPBF LT1374IS8-5#PBF LT1374IS8-5#TRPBF LT1374IS8-5SYNC#PBF LT1374IS8-SYNC#PBF LT1374IT7#PBF LT1374IT7-5#PBF
- Power Management > Switching Regulator > SEPIC Regulators
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
LT1374IS8TRPBF, LT1374IS8 TRPBF
