Datasheet Linear Technology LT1375CS8#TRPBF — Даташит
СерияLT1375
МодельLT1375CS8#TRPBF
Понижающие импульсные регуляторы, 1,5 А, 500 кГц
Datasheet LT1375, LT1376
PDF, 518 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 28
1.5A, 500kHz Step-Down Switching Regulators
14 предложений от 12 поставщиков
, 1.5A, 500kHz Step-Down Switching Regulators
LT1375CS8#TRPBF
193 ₽
LT1375CS8#TRPBF
от 341 ₽
727GS
LT1375CS8-5#TRPBF
от 365 ₽
LT1375CS8-5 TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
АрхитектураConstant Frequency Current Mode
Demo BoardsDC084B-A,DC084B-B
Design ToolsLTspice File
Экспортный контрольнет
Основные особенностиExternal Synchronization
Тактовая частота500 kHz
Frequency Sync Range580kHz - 900kHz
Integrated Inductorнет
Ishutdown20 мкА
Isupply2.5 мА
Max Phases1
Monolithicда
Количество выходов1
Выходной ток1.2 A
Polyphaseнет
Switch Current2 A
Synchronousнет
TopologyBuck
Vin Max25 В
Vin Min5 В
Vout Max21.5 В
Vout Maximum.86VIN
Vout Min2.42 В
Vref Accuracy Over Temp2.5 %
Vswitch Max35 В
LT1375HV LT1376 LT1376 LT1376HV
  • Ultracompact LCD Backlight Inverters &mdash AN81
    PDF, 365 Кб, Файл опубликован: 1 сен 1999
    It has become desirable to fashion laptop computers with large area screens, leaving little room for the display's backlight inverter electronics. Miniaturization limitations of high voltage magnetic transformers impose limits on achievable space reduction. Another voltage step-up technology, piezoelectric transformers, permits the desired size reduction and provides additional benefits. This publication describes practical piezoceramic transformers and support circuitry. Ancillary benefits of the piezoelectric approach are also described. Appended sections detail transformer operation and feedback loop considerations.
  • Power Management > Switching Regulator > SEPIC Regulators
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
LT1375CS8TRPBF, LT1375CS8 TRPBF
На английском языке: Datasheet Linear Technology LT1375CS8#TRPBF
Публикации по теме
