Datasheet Linear Technology LT1534CS#TRPBF — Даташит
СерияLT1534
МодельLT1534CS#TRPBF
Сверхмалошумящий импульсный регулятор 2А
Datasheet LT1534
PDF, 216 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 16
Ultralow Noise 2A Switching Regulators
14 предложений от 10 поставщиков
, Ultralow Noise 2A Switching Regulator
LT1534CS-1#TRPBF
170 ₽
LT1534CS-1#TRPBF
226 ₽
LT1534CS#TRPBF
308 ₽
LT1534CS TRPBF
КорпусSO-16
Код корпусаS
Индекс корпуса05-08-1610 (S16)
Design ToolsLTspice Model
Экспортный контрольнет
Основные особенностиLow EMI, Adjustable Slew Rate, External Synchronization
Тактовая частота250 kHz
Frequency Adjust Range25kHz - 250kHz
Frequency Sync Range25kHz - 375kHz
Integrated Inductorнет
Ishutdown12 мкА
Isupply12 мА
Monolithicда
Количество выходов1
Polyphaseнет
Switch Current2 A
Synchronousнет
TopologyBoost, Flyback, Sepic
Vin Max23 В
Vin Min2.7 В
Vout Max35 В
Vout Min1.3 В
Vswitch Max35 В
LT1534-1
  • High Voltage, Low Noise, DC/DC Converters &mdash AN118
    PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
    Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
  • Circuitry for Signal Conditioning and Power Conversion &mdash AN75
    PDF, 508 Кб, Файл опубликован: 1 мар 1999
    This publication includes designs for data converters and signal conditioners, transducer circuits, crystal oscillators and power converters. Wideband and micropower circuitry receive special attention. Tutorials on micropower design techniques and parasitic effects of test equipment are included.
Design Notes
  • LT1534 Ultralow Noise Switching Regulator Controls EMI &mdash DN178
    PDF, 99 Кб, Файл опубликован: 1 апр 1998
Серия: LT1534 (4)
  • Power Management > Switching Regulator > Ultralow Noise Regulators
LT1534CSTRPBF, LT1534CS TRPBF
На английском языке: Datasheet Linear Technology LT1534CS#TRPBF
Публикации по теме
