Datasheet Linear Technology LT1683IG#TRPBF — Даташит
Серия | LT1683 |
Модель | LT1683IG#TRPBF |
Двухтактный контроллер постоянного/постоянного тока со сверхнизким уровнем шума и регулируемой скоростью нарастания напряжения
Datasheet LT1683
PDF, 419 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 26
Slew Rate Controlled Ultralow Noise Push-Pull DC/DC Controller
![]() 15 предложений от 12 поставщиков Push-Pull Regulator Positive and Negative Output Step-Up/Step-Down DC-DC Controller IC 20-SSOP | |||
LT1683IG#TRPBF Analog Devices | 270 ₽ | ||
LT1683IG#TRPBF Linear Technology | 551 ₽ | ||
LT1683IG#TRPBF | 683 ₽ | ||
LT1683IG#TRPBF Analog Devices | по запросу |
Корпус | SSOP-20 |
Код корпуса | G |
Индекс корпуса | 05-08-1640 (G20) |
Demo Boards | DC477A |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | Low EMI, Adjustable Slew Rate |
Тактовая частота | 250 kHz |
Integrated Inductor | нет |
Isupply | 25 мА |
Monolithic | нет |
Количество выходов | 1 |
Polyphase | нет |
Switch Current | 5 A |
Synchronous | нет |
Topology | Push-Pull, Inverting, Boost, Flyback |
Vin Max | 20 В |
Vin Min | 4 В |
Vout Max | 100 В |
Vout Min | 5 В |
Vswitch Max | 100 В |
- Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90PDF, 409 Кб, Файл опубликован: 1 апр 2002
A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.Выписка из документа
Статьи
- Reduce EMI with Ultralow Noise 48V to 5V, 10W DC/DC Converter &mdash LT JournalPDF, 209 Кб, Файл опубликован: 1 фев 2001Выписка из документа
- Two New Switching Regulators Deliver Both Power and Ultralow Noise &mdash LT JournalPDF, 219 Кб, Файл опубликован: 1 сен 2001Выписка из документа
Серия: LT1683 (4)
- LT1683EG#PBF LT1683EG#TRPBF LT1683IG#PBF LT1683IG#TRPBF
- Power Management > Switching Regulator > Ultralow Noise Regulators
LT1683IGTRPBF, LT1683IG TRPBF
