Datasheet Linear Technology LT3468ES5-1#TRMPBF — Даташит
СерияLT3468-1
МодельLT3468ES5-1#TRMPBF
Зарядные устройства для конденсаторов Photoflash в ThinSOT
LT3468/LT3468-1/LT3468-2 - Photoflash Capacitor Chargers in ThinSOT
PDF, 465 Кб, Версия: A, Файл закачен: 18 сен 2017
28 предложений от 13 поставщиков
, Photoflash Capacitor Chargers in ThinSOTTM
LT3468ES5-1#TRMPBF
115 ₽
727GS
LT3468ES5-1#TRMPBF
от 252 ₽
LT3468ES5-1#TRMPBF
508 ₽
ЗУМ-СМД
LT3468ES5-1#TRMPBF
КорпусSOT-23
Код корпусаS5
Индекс корпуса05-08-1635
Demo BoardsDC661A-A,DC661A-B,DC711A-A,DC711A-B,DC711A-C,DC796A
Design ToolsLTspice File
Экспортный контрольнет
Integrated Inductorнет
Ishutdown1 мкА
Isupply5 мА
Monolithicда
Количество выходов1
Рабочий диапазон температурот 0 до 85 °C
Polyphaseнет
Switch Current0.55 A
Synchronousнет
TopologyFlyback, Photoflash
Vin Max16 В
Vin Min2.5 В
LT3468 LT3468-2
  • High Voltage, Low Noise, DC/DC Converters &mdash AN118
    PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
    Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
Design Notes
  • Basic Flashlamp Illumination Circuitry for Cellular Telephones/Cameras &mdash DN345
    PDF, 110 Кб, Файл опубликован: 2 сен 2004
Статьи
  • Photoflash Capacitor Chargers Fit into Tight Spots &mdash LT Journal
    PDF, 379 Кб, Файл опубликован: 1 дек 2003
Серия: LT3468-1 (2)
  • Power Management > Switching Regulator > Xenon Photoflash Charger
LT3468ES5-1TRMPBF, LT3468ES5-1 TRMPBF, LT3468ES51#TRMPBF, LT3468ES5 1#TRMPBF
На английском языке: Datasheet Linear Technology LT3468ES5-1#TRMPBF
Публикации по теме
