Datasheet Linear Technology LT3752-1 — Даташит
СерияLT3752-1
Активные фиксированные синхронные форвардные контроллеры с внутренним вспомогательным контроллером
LT3752: Active Clamp Synchronous Forward Controllers with Internal Housekeeping Controller Data Sheet
PDF, 618 Кб, Файл закачен: 19 сен 2017
LT3752-1: 75-150Vin 24Vout@14A
LT3752EFE-1#PBFLT3752EFE-1#TRPBFLT3752HFE-1#PBFLT3752HFE-1#TRPBFLT3752IFE-1#PBFLT3752IFE-1#TRPBFLT3752MPFE-1#PBFLT3752MPFE-1#TRPBF
N12345678
КорпусTSSOP-38
Габаритный чертеж корпуса
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
Код корпусаFEFEFEFEFEFEFEFE
Индекс корпуса05-08-186505-08-186505-08-186505-08-186505-08-186505-08-186505-08-186505-08-1865
Количество выводов3838383838383838
Parameters / ModelsLT3752EFE-1#PBFLT3752EFE-1#TRPBFLT3752HFE-1#PBFLT3752HFE-1#TRPBFLT3752IFE-1#PBFLT3752IFE-1#TRPBFLT3752MPFE-1#PBFLT3752MPFE-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1994A,DC1929A,DC2175ADC1994A,DC1929A,DC2175ADC1994A,DC1929A,DC2175ADC1994A,DC1929A,DC2175ADC1994A,DC1929A,DC2175ADC1994A,DC1929A,DC2175ADC1994A,DC1929A,DC2175ADC1994A,DC1929A,DC2175A
Design ToolsLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice File
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set FrequencyInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set FrequencyInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set FrequencyInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set FrequencyInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set FrequencyInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set FrequencyInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set FrequencyInternal Housekeeping DC/DC, Programmable Volt Second Clamp, Active Clamp, External Synchronization, Resistor Set Frequency
Тактовая частота, kHz500500500500500500500500
Frequency Adjust Range100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz
Frequency Sync Range100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz100kHz - 500kHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА165165165165165165165165
Isupply, мА7.57.57.57.57.57.57.57.5
Monolithicнетнетнетнетнетнетнетнет
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Switch Current, A2525252525252525
Synchronousдададададададада
TopologyForwardForwardForwardForwardForwardForwardForwardForward
Topology 1ForwardForwardForwardForwardForwardForwardForwardForward
Vin Max, В400400400400400400400400
Vin Min, В1010101010101010
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LT3752 LT3752 LT3752-1
Статьи
  • Active Clamp Synchronous Controllers for Forward Converters with 6.5V to 100V+ Inputs &mdash LT Journal
    PDF, 704 Кб, Файл опубликован: 9 апр 2014
  • Power Management > Switching Regulator > Flyback, Forward and Isolated Controllers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LT3752-1
