Datasheet Linear Technology LT3758AHMSE#TRPBF — Даташит
СерияLT3758A
МодельLT3758AHMSE#TRPBF
Высокое входное напряжение, усиление, обратная связь, SEPIC и инвертирующий контроллер
LT3758: High Input Voltage, Boost, Flyback, SEPIC and Inverting Controller Data Sheet
PDF, 862 Кб, Файл закачен: 19 сен 2017
IC REG CTRLR MULT TOP 10MSOP. Boost, Flyback, SEPIC Regulator Positive or Negative, Isolation Capable Output Step-Up, Step-Up/Step-Down DC-DC Controller IC...
LT3758AHMSE#TRPBF
168 ₽
LT3758AHMSE#TRPBF
233 ₽
LT3758AHMSE#TRPBF
316 ₽
LT3758AHMSE#TRPBF
КорпусMS-10E
Код корпусаMSE
Индекс корпуса05-08-1664
АрхитектураConstant Frequency Current Mode
Demo BoardsDC1412A,DC1342B
Design ToolsLTspice File,LTpowerCAD Model
Экспортный контрольнет
Основные особенностиResistor Set Frequency, External Synchronization
Тактовая частота1000 kHz
Frequency Adjust Range100kHz - 1MHz
Frequency Sync Range100kHz - 1MHz
Integrated Inductorнет
Ishutdown6 мкА
Isupply1.6 мА
Max Phases1
Monolithicнет
Количество выходов1
Рабочий диапазон температурот -40 до 125 °C
Polyphaseнет
Sense ResistorRsense
Switch Current25 A
Synchronousнет
TopologyBoost, Flyback, Sepic, Inverting
Vin Max100 В
Vin Min5.5 В
Vin Min Startup5.5 В
Vout Max350 В
Vout MaximumLimited by external components
Vout Min1.6 В
Vswitch Max350 В
  • 2-Wire Virtual Remote Sensing for Voltage Regulators - Clairvoyance Marries Remote Sensing &mdash AN126
    PDF, 1.4 Мб, Файл опубликован: 1 окт 2010
    Wires and connectors have resistance. This simple, unavoidable truth dictates that a power source’s remote load voltage will be less than the source’s output voltage. Traditional methods for countering this include increasing the power source voltage and "4-wire" remote voltage sensing. Both have limitations. A new IC based approach achieves "virtual" remote sensing at the load without adding the usual two extra sense wires. Numerous circuit examples show the IC working with various voltage regulators and remote loads. Appendices detail IC internal operation and design guidelines for applying the part in any regulator circuit.
Статьи
  • Two New Controllers for Boost, Flyback, SEPIC and Inverting DC/DC Converters Accept Inputs up to 100V &mdash LT Journal
    PDF, 457 Кб, Файл опубликован: 1 июн 2009
  • Power Management > Switching Regulator > SEPIC Regulators | Flyback, Forward and Isolated Controllers | Inverting Regulators
  • Power Management > Switching Regulator > Step-Up (Boost) Regulators > External Power Switch Boost
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
LT3758AHMSETRPBF, LT3758AHMSE TRPBF
На английском языке: Datasheet Linear Technology LT3758AHMSE#TRPBF
