Datasheet IRFL4105PBF - International Rectifier Даташит Полевой транзистор, N, SOT-223 — Даташит
Наименование модели: IRFL4105PBF
Купить IRFL4105PBF на РадиоЛоцман.Цены — от 20 до 116 ₽18 предложений от 16 поставщиков Дискретные полупроводники Транзисторы — полевые — одиночные | |||
| IRFL4105PBF Infineon | 23 ₽ | ||
| IRFL4105PBF Infineon | от 116 ₽ | ||
| IRFL4105PBF International Rectifier | по запросу | ||
| IRFL4105PBF Infineon | по запросу | ||
Описание: Полевой транзистор, N, SOT-223
PD- 95319
IRFL4105PbF
HEXFET® Power MOSFET
Surface Mount Advanced Process Technology Ultra Low On-Resistance Dynamic dv/dt Rating Fast Switching Fully Avalanche Rated Lead-Free Description
Fifth Generation HEXFETs from International Rectifier utilize advanced processing techniques to achieve extremely low on-resistance per silicon area.
This benefit, combined with the fast switching speed and ruggedized device design that HEXFET Power MOSFETs are well known for, provides the designer with an extremely efficient and reliable device for use in a wide variety of applications. The SOT-223 package is designed for surface-mount using vapor phase, infra red, or wave soldering techniques. Its unique package design allows for easy automatic pickand-place as with other SOT or SOIC packages but has the added advantage of improved thermal performance due to an enlarged tab for heatsinking. Power dissipation of 1.0W is possible in a typical surface mount application.
- Continuous Drain Current Id: 3.7 А
- Drain Source Voltage Vds: 55 В
- On Resistance Rds(on): 45 МОм
- Voltage Vgs Max: 4 В
- Корпус транзистора: SOT-223
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 3.7 А
- Current Temperature: 25°C
- External Depth: 7.3 мм
- Внешняя длина / высота: 1.7 мм
- Внешняя ширина: 6.7 мм
- Количество транзисторов: 1
- Тип корпуса: SOT-223
- Power Dissipation Pd: 2.1 Вт
- Pulse Current Idm: 30 А
- SMD Marking: FL4105
- Способ монтажа: SMD
- Threshold Voltage Vgs Typ: 4 В
- Voltage Vds Typ: 55 В
- Voltage Vgs Rds on Measurement: 10 В
- Voltage Vgs th Max: 2 В
RoHS: Y-Ex
Дополнительные аксессуары:
- Panasonic - EYGA091203SM
- Panasonic - EYGA121807A
- Roth Elektronik - RE901
