Datasheet Linear Technology LT8607 — Даташит
СерияLT8607
Синхронный понижающий стабилизатор 42 В, 750 мА с током покоя 2,5 мкА
LT8607: 42V, 750mA Synchronous Step-Down Regulator with 2.5µA Quiescent Current Data Sheet
PDF, 1.6 Мб, Файл закачен: 27 мар 2018
36 предложений от 15 поставщиков
LT8607EDC#TRPBF
от 64 ₽
LT8607EMSE#PBF
113 ₽
Microfind
LT8607IMSE#TRPBF
300 ₽
LT8607EMSE#TRPBF
от 471 ₽
LT8607EDC#PBFLT8607EDC#TRMPBFLT8607EDC#TRPBFLT8607EMSE#PBFLT8607EMSE#TRPBFLT8607HDC#PBFLT8607HDC#TRMPBFLT8607HDC#TRPBFLT8607HMSE#PBFLT8607HMSE#TRPBFLT8607IDC#PBFLT8607IDC#TRMPBFLT8607IDC#TRPBFLT8607IMSE#PBFLT8607IMSE#TRPBF
N123456789101112131415
Корпус2x2 DFN-8
Габаритный чертеж корпуса
2x2 DFN-8
2x2 DFN-8
MS-10E
MS-10E
2x2 DFN-8
2x2 DFN-8
2x2 DFN-8
2x2 DFN-8
2x2 DFN-8
2x2 DFN-8
2x2 DFN-8
2x2 DFN-8
MS-10E
MS-10E
Код корпусаDC8DC8DC8MSEMSEDC8DC8DC8DC8DC8DC8DC8DC8MSEMSE
Индекс корпуса05-08-193905-08-193905-08-193905-08-166405-08-166405-08-193905-08-193905-08-193905-08-193905-08-193905-08-193905-08-193905-08-193905-08-166405-08-1664
Количество выводов8881010888888881010
Parameters / ModelsLT8607EDC#PBFLT8607EDC#TRMPBFLT8607EDC#TRPBFLT8607EMSE#PBFLT8607EMSE#TRPBFLT8607HDC#PBFLT8607HDC#TRMPBFLT8607HDC#TRPBFLT8607HMSE#PBFLT8607HMSE#TRPBFLT8607IDC#PBFLT8607IDC#TRMPBFLT8607IDC#TRPBFLT8607IMSE#PBFLT8607IMSE#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565ADC2565A
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power GoodBurst Mode, Spread Spectrum, Resistor Set Frequency, External Synchronization, Power Good
Тактовая частота, kHz220022002200220022002200220022002200220022002200220022002200
Frequency Adjust Range200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz
Frequency Sync Range200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz200kHz to 2.2MHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА111111111111111
Isupply, мА0.00170.00170.00170.00170.00170.00170.00170.00170.00170.00170.00170.00170.00170.00170.0017
Monolithicдадададададададададададададада
Количество выходов111111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A0.750.750.750.750.750.750.750.750.750.750.750.750.750.750.75
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Switch Current, A1.51.51.51.51.51.51.51.51.51.51.51.51.51.51.5
Synchronousдадададададададададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В424242424242424242424242424242
Vin Min, В333333333333333
Vout Max, В41.441.441.441.441.441.441.441.441.441.441.441.441.441.441.4
Vout Min, В0.7780.7780.7780.7780.7780.7780.7780.7780.7780.7780.7780.7780.7780.7780.778
Vref Accuracy Over Temp, %2.52.52.52.52.52.52.52.52.52.52.52.52.52.52.5
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > High Input Voltage Buck | Micropower Buck Regulators | Internal Power Switch Buck
На английском языке: Datasheet Linear Technology LT8607
Публикации по теме
