Datasheet Linear Technology LTC1174HVCS8#TRPBF — Даташит
СерияLTC1174HV
МодельLTC1174HVCS8#TRPBF
Высокоэффективный понижающий и инвертирующий преобразователь постоянного тока в постоянный ток
Datasheet LTC1174, LTC1174-3.3, LTC1174-5
PDF, 263 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 20
High Efficiency Step-Down and Inverting DC/DC Converter
14 предложений от 14 поставщиков
IC REG BUCK BST 5V 8SOIC. Buck, Buck-Boost Switching Regulator IC Positive or Negative Fixed 5V 1 Output 340mA, 600mA 8-SOIC...
Рутоника
LTC1174HVCS8-5#TRPBF
421 ₽
SUV System
LTC1174HVCS8-3.3#TRPBF
TradeElectronics
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
АрхитектураConstant Off-Time Current Mode
Demo BoardsDC059A-A,DC059A-B,DC059A-C
Design ToolsLTspice Model
Экспортный контрольнет
Основные особенностиFixed Output
Тактовая частота200 kHz
Integrated Inductorнет
Ishutdown1 мкА
Isupply0.13 мА
Max Phases1
Monolithicда
Количество выходов1
Выходной ток0.432 A
Polyphaseнет
Switch Current0.6 A
Synchronousнет
TopologyBuck, Inverting
Vin Max18.5 В
Vin Min4 В
Vout Max18 В
Vout Maximum0.70Vin
Vout Min1.25 В
Vref Accuracy Over Temp4 %
Vswitch Max18.5 В
LTC1174 LTC1174
  • Linear Technology Magazine Circuit Collection, Volume II &mdash AN66
    PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
    Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.
Design Notes
  • A Simple High Efficiency, Step-Down Switching Regulator &mdash DN73
    PDF, 78 Кб, Файл опубликован: 1 авг 1993
  • Techniques for Deriving 3.3V from 5V Supplies &mdash DN74
    PDF, 73 Кб, Файл опубликован: 1 сен 1993
  • Ultra-Low Power, High Efficiency DC/DC Converter Operates Outside the Audio Band &mdash DN86
    PDF, 73 Кб, Файл опубликован: 1 сен 1994
  • 5V to 3.3V Circuit Collection &mdash DN91
    PDF, 74 Кб, Файл опубликован: 1 ноя 1994
  • Power Management > Switching Regulator > Inverting Regulators
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
LTC1174HVCS8TRPBF, LTC1174HVCS8 TRPBF
На английском языке: Datasheet Linear Technology LTC1174HVCS8#TRPBF
