Datasheet Linear Technology LTC1622IS8#TRPBF — Даташит
СерияLTC1622
МодельLTC1622IS8#TRPBF
Понижающий DC / DC-регулятор в режиме низкого входного напряжения и тока
Datasheet LTC1622
PDF, 198 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 16
Low Input Voltage Current Mode Step-Down DC/DC Controller
15 предложений от 15 поставщиков
IC REG CTRLR BUCK 8SOIC. Buck Regulator Positive Output Step-Down DC-DC Controller IC 8-SOIC. PMIC - Voltage Regulators - DC DC...
LTC1622IS8#TRPBF
135 ₽
Рутоника
LTC1622IS8#TRPBF
226 ₽
SUV System
LTC1622IS8#TRPBF
Hi-Tech Circuit Group
LTC1622IS8#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
АрхитектураConstant Frequency Current Mode
Demo BoardsDC232A
Design ToolsLTspice Model
Экспортный контрольнет
Основные особенности100% Duty Cycle
Тактовая частота550 kHz
Integrated Inductorнет
Ishutdown4 мкА
Isupply0.27 мА
Max Phases1
Monolithicнет
Количество выходов1
Выходной ток5 A
Polyphaseнет
Sense ResistorRsense
Switch Current5 A
Synchronousнет
TopologyBuck
Vin Max9.8 В
Vin Min2 В
Vout Max9.8 В
Vout MaximumVin
Vout Min0.8 В
Vref Accuracy Over Temp1.9 %
  • Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84
    PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
    Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.
Design Notes
  • Low Dropout 550kHz DC/DC Controller Operates from Inputs as Low as 2V &mdash DN208
    PDF, 88 Кб, Файл опубликован: 2 июл 1999
Статьи
  • LTC1622: Low Input Voltage, Current Mode PWM Buck Converter &mdash LT Journal
    PDF, 245 Кб, Файл опубликован: 1 ноя 1998
  • Using Current Sensing Resistors with Hot Swap Controllers and Current Mode Voltage Regulators &mdash LT Journal
    PDF, 142 Кб, Файл опубликован: 1 сен 2003
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC1622IS8TRPBF, LTC1622IS8 TRPBF
На английском языке: Datasheet Linear Technology LTC1622IS8#TRPBF
Публикации по теме
