Datasheet Linear Technology LTC1624IS8#PBF — Даташит
Серия | LTC1624 |
Модель | LTC1624IS8#PBF |
Высокоэффективный контроллер регулятора коммутации с N-каналом SO-8
Datasheet LTC1624
PDF, 413 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 28
High Efficiency SO-8 N-Channel Switching Regulator Controller
![]() 42 предложений от 23 поставщиков Преобразователь DC/DC, High Efficiency SO-8 N-Channel Switching Regulator Controllers | |||
LTC1624IS8#TRPBF Analog Devices | от 185 ₽ | ||
LTC1624IS8#PBF Analog Devices | 308 ₽ | ||
LTC1624IS8#PBF Linear Technology | 315 ₽ | ||
LTC1624IS8#TRPBF Analog Devices | от 1 280 ₽ |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC164A |
Design Tools | LTspice File |
Экспортный контроль | нет |
Тактовая частота | 200 kHz |
Integrated Inductor | нет |
Ishutdown | 16 мкА |
Isupply | 0.5 мА |
Max Phases | 1 |
Monolithic | нет |
Количество выходов | 1 |
Выходной ток | 5 A |
Polyphase | нет |
Sense Resistor | Rsense |
Switch Current | 5 A |
Synchronous | нет |
Topology | Buck, Boost, Sepic, Inverting, Flyback |
Vin Max | 36 В |
Vin Min | 3.5 В |
Vout Max | 34.2 В |
Vout Maximum | 0.95VIN |
Vout Min | 1.19 В |
Vref Accuracy Over Temp | 1 % |
Vswitch Max | 36 В |
- Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.Выписка из документа
Статьи
- VID Voltage Programmer for Intel Mobile Processors &mdash LT JournalPDF, 250 Кб, Файл опубликован: 1 авг 1998Выписка из документа
- Wide-Input-Range, Low Voltage Flyback Regulator &mdash LT JournalPDF, 218 Кб, Файл опубликован: 1 май 1998Выписка из документа
Серия: LTC1624 (4)
- LTC1624CS8#PBF LTC1624CS8#TRPBF LTC1624IS8#PBF LTC1624IS8#TRPBF
- Power Management > Switching Regulator > Inverting Regulators | SEPIC Regulators
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC1624IS8PBF, LTC1624IS8 PBF
