Datasheet Linear Technology LTC1735CGN#TRPBF — Даташит
СерияLTC1735
МодельLTC1735CGN#TRPBF
Высокоэффективный синхронный понижающий импульсный регулятор
Datasheet LTC1735
PDF, 415 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 32
High Efficiency Synchronous Step-Down Switching Regulator
, High Efficiency Synchronous Step-Down Switching Regulator
LTC1735CGN-1#TRPBF
147 ₽
LTC1735CGN-1#TRPBF
902 ₽
LTC1735CGN-1#TRPBF
TradeElectronics
LTC1735CGN#TRPBF
КорпусSSOP-16
Код корпусаGN
Индекс корпуса05-08-1641 (GN16)
АрхитектураConstant Frequency Current Mode
Demo BoardsDC222A,DC247A
Design ToolsLTspice Model
Экспортный контрольнет
Основные особенностиExternal Synchronization, Resistor Set Frequency, Active Voltage Positioning, Power Good, Soft Start
Тактовая частота300 kHz
Frequency Adjust RangeUp to 500kHz
Frequency Sync RangeUp to 500kHz
Integrated Inductorнет
Ishutdown15 мкА
Isupply0.45 мА
Max Phases1
Monolithicнет
Количество выходов1
Выходной ток20 A
Polyphaseнет
Sense ResistorRsense
Switch Current20 A
Synchronousда
TopologyBuck
Vin Max36 В
Vin Min3.5 В
Vout Max7 В
Vout Maximum7V
Vout Min0.8 В
Vref Accuracy Over Temp1 %
  • OPTI-LOOP Architecture Reduces Output Capacitance and Improves Transient Response &mdash AN76
    PDF, 271 Кб, Файл опубликован: 1 май 1999
    Loop compensation is an uncomfortable subject for many engineers. Experienced power supply designers know that optimum loop compensation is necessary to get the best performance from their power supplies. This application note discusses power supply loop compensation utilizing the features provided by the OPTILOOPTM architecture. Loop compensation basics are presented and simple equations are given for frequency response approximations. Typical transient response requirements for the system supply and CPU supply, used in notebook computers, are discussed. Output voltage transient response waveforms and Bode plots are shown for both optimized and nonoptimized control loops as well as for circuits with optimized loops using different output capacitors. Although this publication focuses on circuits using the LTC1628, LTC1735 and LTC1736, the information applies to all regulators equipped with OPTI-LOOP architecture.
Design Notes
  • Active Voltage Positioning Reduces Output Capacitors &mdash Design Solutions 10
    PDF, 130 Кб, Файл опубликован: 1 ноя 1999
  • LTC1735 Provides Low Cost, Efficient Mobile CPU Power &mdash DN199
    PDF, 78 Кб, Файл опубликован: 1 мар 1999
  • 2-Step Voltage Regulation Improves Performance and Decreases CPU Temperature in Portable Computers &mdash DN209
    PDF, 79 Кб, Файл опубликован: 1 авг 1999
  • Microprocessor Core Supply Voltage Set by I2C Bus Without VID Lines &mdash DN279
    PDF, 75 Кб, Файл опубликован: 1 мар 2002
Статьи
  • Third-Generation DC/DC Controllers Reduce Size and Cost &mdash LT Journal
    PDF, 140 Кб, Файл опубликован: 1 фев 1999
  • Active Voltage Positioning Saves Output Capacitors in Portable Computer Applications &mdash LT Journal
    PDF, 169 Кб, Файл опубликован: 1 фев 2000
  • LTC1645/LTC1735 Circuit Solves PCI Power Problem &mdash LT Journal
    PDF, 232 Кб, Файл опубликован: 1 фев 2000
  • A Third Generation Dual, Opposing-Phase Switching Regulator Controller &mdash LT Journal
    PDF, 172 Кб, Файл опубликован: 1 июн 1999
  • SMBus Controls CPU Voltage Regulators without VID Pins &mdash LT Journal
    PDF, 148 Кб, Файл опубликован: 1 сен 2001
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC1735CGNTRPBF, LTC1735CGN TRPBF
На английском языке: Datasheet Linear Technology LTC1735CGN#TRPBF
Публикации по теме
