Datasheet Linear Technology LTC1735IS#PBF — Даташит
Серия | LTC1735 |
Модель | LTC1735IS#PBF |
Высокоэффективный синхронный понижающий импульсный регулятор
Datasheet LTC1735
PDF, 415 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 32
High Efficiency Synchronous Step-Down Switching Regulator
![]() 33 предложений от 23 поставщиков IC REG CTRLR BUCK 16SOIC / DC/DC Cntrlr Single-OUT Step Down 500kHz Automotive 16-Pin SOIC N Tube | |||
LTC1735IS-1#PBF Linear Technology | от 405 ₽ | ||
LTC1735IS#PBF Analog Devices | 987 ₽ | ||
LTC1735IS Analog Devices | 1 479 ₽ | ||
LTC1735IS16P | по запросу |
Корпус | SO-16 |
Код корпуса | S |
Индекс корпуса | 05-08-1610 (S16) |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC222A,DC247A |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | External Synchronization, Resistor Set Frequency, Active Voltage Positioning, Power Good, Soft Start |
Тактовая частота | 300 kHz |
Frequency Adjust Range | Up to 500kHz |
Frequency Sync Range | Up to 500kHz |
Integrated Inductor | нет |
Ishutdown | 15 мкА |
Isupply | 0.45 мА |
Max Phases | 1 |
Monolithic | нет |
Количество выходов | 1 |
Выходной ток | 20 A |
Polyphase | нет |
Sense Resistor | Rsense |
Switch Current | 20 A |
Synchronous | да |
Topology | Buck |
Vin Max | 36 В |
Vin Min | 3.5 В |
Vout Max | 7 В |
Vout Maximum | 7V |
Vout Min | 0.8 В |
Vref Accuracy Over Temp | 1 % |
- OPTI-LOOP Architecture Reduces Output Capacitance and Improves Transient Response &mdash AN76PDF, 271 Кб, Файл опубликован: 1 май 1999
Loop compensation is an uncomfortable subject for many engineers. Experienced power supply designers know that optimum loop compensation is necessary to get the best performance from their power supplies. This application note discusses power supply loop compensation utilizing the features provided by the OPTILOOPTM architecture. Loop compensation basics are presented and simple equations are given for frequency response approximations. Typical transient response requirements for the system supply and CPU supply, used in notebook computers, are discussed. Output voltage transient response waveforms and Bode plots are shown for both optimized and nonoptimized control loops as well as for circuits with optimized loops using different output capacitors. Although this publication focuses on circuits using the LTC1628, LTC1735 and LTC1736, the information applies to all regulators equipped with OPTI-LOOP architecture.Выписка из документа
Design Notes
- Active Voltage Positioning Reduces Output Capacitors &mdash Design Solutions 10PDF, 130 Кб, Файл опубликован: 1 ноя 1999Выписка из документа
- LTC1735 Provides Low Cost, Efficient Mobile CPU Power &mdash DN199PDF, 78 Кб, Файл опубликован: 1 мар 1999Выписка из документа
- 2-Step Voltage Regulation Improves Performance and Decreases CPU Temperature in Portable Computers &mdash DN209PDF, 79 Кб, Файл опубликован: 1 авг 1999Выписка из документа
- Microprocessor Core Supply Voltage Set by I2C Bus Without VID Lines &mdash DN279PDF, 75 Кб, Файл опубликован: 1 мар 2002Выписка из документа
Статьи
- Third-Generation DC/DC Controllers Reduce Size and Cost &mdash LT JournalPDF, 140 Кб, Файл опубликован: 1 фев 1999Выписка из документа
- Active Voltage Positioning Saves Output Capacitors in Portable Computer Applications &mdash LT JournalPDF, 169 Кб, Файл опубликован: 1 фев 2000Выписка из документа
- LTC1645/LTC1735 Circuit Solves PCI Power Problem &mdash LT JournalPDF, 232 Кб, Файл опубликован: 1 фев 2000Выписка из документа
- A Third Generation Dual, Opposing-Phase Switching Regulator Controller &mdash LT JournalPDF, 172 Кб, Файл опубликован: 1 июн 1999Выписка из документа
- SMBus Controls CPU Voltage Regulators without VID Pins &mdash LT JournalPDF, 148 Кб, Файл опубликован: 1 сен 2001Выписка из документа
Серия: LTC1735 (14)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC1735ISPBF, LTC1735IS PBF
