Datasheet Linear Technology LTC1736IG#PBF — Даташит
Серия | LTC1736 |
Модель | LTC1736IG#PBF |
5-битный регулируемый высокоэффективный синхронный понижающий импульсный регулятор
LTC1736 - 5-Bit Adjustable High Efficiency Synchronous Step-Down Switching Regulator
PDF, 341 Кб, Файл закачен: 20 сен 2017
![]() 27 предложений от 17 поставщиков Чип стабилизации напряжения, LTC1736 - 5Bit Adjustable High Efficiency Synchronous Step-Down Switching Regulator | |||
LTC1736IG#PBF Analog Devices | 299 ₽ | ||
LTC1736IG Linear Technology | по запросу | ||
LTC1736IG Analog Devices | по запросу | ||
LTC1736IG#PBF Linear Technology | по запросу |
Корпус | SSOP-24 |
Код корпуса | G |
Индекс корпуса | 05-08-1640 (G24) |
Demo Boards | DC252A,DC279A-B |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | VID, Active Voltage Positioning, Resistor Set Frequency, External Synchronization, Power Good |
Тактовая частота | 300 kHz |
Frequency Adjust Range | Up to 500kHz |
Frequency Sync Range | Up to 500kHz |
Integrated Inductor | нет |
Ishutdown | 15 мкА |
Isupply | 0.45 мА |
Max Phases | 2 |
Monolithic | нет |
Количество выходов | 1 |
Выходной ток | 20 A |
Polyphase | нет |
Switch Current | 20 A |
Synchronous | да |
Topology | Buck |
Vin Max | 36 В |
Vin Min | 4 В |
Vout Max | 2 В |
Vout Min | 0.925 В |
- OPTI-LOOP Architecture Reduces Output Capacitance and Improves Transient Response &mdash AN76PDF, 271 Кб, Файл опубликован: 1 май 1999
Loop compensation is an uncomfortable subject for many engineers. Experienced power supply designers know that optimum loop compensation is necessary to get the best performance from their power supplies. This application note discusses power supply loop compensation utilizing the features provided by the OPTILOOPTM architecture. Loop compensation basics are presented and simple equations are given for frequency response approximations. Typical transient response requirements for the system supply and CPU supply, used in notebook computers, are discussed. Output voltage transient response waveforms and Bode plots are shown for both optimized and nonoptimized control loops as well as for circuits with optimized loops using different output capacitors. Although this publication focuses on circuits using the LTC1628, LTC1735 and LTC1736, the information applies to all regulators equipped with OPTI-LOOP architecture.Выписка из документа
Design Notes
- Active Voltage Positioning Reduces Output Capacitors &mdash Design Solutions 10PDF, 130 Кб, Файл опубликован: 1 ноя 1999Выписка из документа
- 2-Phase DC/DC Controller Reduces Capacitanceand Increases Battery Life in Portable Applications &mdash Design Solutions 9PDF, 106 Кб, Файл опубликован: 1 июн 1999Выписка из документа
- LTC1735 Provides Low Cost, Efficient Mobile CPU Power &mdash DN199PDF, 78 Кб, Файл опубликован: 1 мар 1999Выписка из документа
- 2-Step Voltage Regulation Improves Performance and Decreases CPU Temperature in Portable Computers &mdash DN209PDF, 79 Кб, Файл опубликован: 1 авг 1999Выписка из документа
- Active Voltage Positioning Reduces Output Capacitors &mdash DN224PDF, 86 Кб, Файл опубликован: 1 ноя 1999Выписка из документа
Статьи
- Third-Generation DC/DC Controllers Reduce Size and Cost &mdash LT JournalPDF, 140 Кб, Файл опубликован: 1 фев 1999Выписка из документа
- Active Voltage Positioning Saves Output Capacitors in Portable Computer Applications &mdash LT JournalPDF, 169 Кб, Файл опубликован: 1 фев 2000Выписка из документа
Серия: LTC1736 (4)
- LTC1736CG#PBF LTC1736CG#TRPBF LTC1736IG#PBF LTC1736IG#TRPBF
- Power Management > Switching Regulator > Digitally Programmable Regulators
LTC1736IGPBF, LTC1736IG PBF
