Datasheet Linear Technology LTC3729EUH#TRPBF — Даташит
СерияLTC3729
МодельLTC3729EUH#TRPBF
550 кГц, PolyPhase, высокоэффективный синхронный понижающий импульсный регулятор
Datasheet LTC3729
PDF, 356 Кб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 30
550kHz, PolyPhase, High Efficiency, Synchronous Step-Down Switching Regulator
, 550kHz, PolyPhase, High Efficiency, Synchronous Step-Down Switching Regulator
LTC3729EUH#TRPBF
470 ₽
Hi-Tech Circuit Group
LTC3729EUH#TRPBF
LTC3729EUH#TRPBF
TradeElectronics
LTC3729EUH#TRPBF
Корпус5x5 QFN-32
Код корпусаUH
Индекс корпуса05-08-1693
АрхитектураConstant Frequency Current Mode
Demo BoardsDC509B
Design ToolsLTspice Model
Экспортный контрольнет
Основные особенностиPolyPhase
Тактовая частота550 kHz
Integrated Inductorнет
Ishutdown20 мкА
Isupply0.58 мА
Max Phases2, 3, 4, 6, 8, 12
Monolithicнет
Количество выходов1
Рабочий диапазон температурот 0 до 85 °C
Выходной ток40 A
Polyphaseда
Sense ResistorRsense
Switch Current40 A
Synchronousда
TopologyBuck
Vin Max36 В
Vin Min4 В
Vout Max5 В
Vout Maximum5V
Vout Min0.8 В
Vref Accuracy Over Temp1 %
  • PCB Layout Considerations for Non-Isolated Switching Power Supplies &mdash AN136
    PDF, 215 Кб, Файл опубликован: 20 сен 2012
    The best news when you power up a prototype supply board for the very first time is when it not only works, but also runs quiet and cool. Unfortunately, this does not always happen. A common problem of switching power supplies is “unstable” switching waveforms. Sometimes, waveform jittering is so pronounced that audible noise can be heard from the magnetic components. If the problem is related to the printed circuit board (PCB) layout, identifying the cause can be difficult. This is why proper PCB layout at the early stage of a switching supply design is very critical. Its importance cannot be overstated.
Design Notes
  • Active Voltage Positioning Reduces Output Capacitors &mdash Design Solutions 10
    PDF, 130 Кб, Файл опубликован: 1 ноя 1999
Статьи
  • Low Voltage, High Current DC/DC Power Supply with Load Sharing and Redundancy &mdash LT Journal
    PDF, 183 Кб, Файл опубликован: 9 авг 2004
Серия: LTC3729 (4)
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC3729EUHTRPBF, LTC3729EUH TRPBF
На английском языке: Datasheet Linear Technology LTC3729EUH#TRPBF
Публикации по теме
