Datasheet Linear Technology LTC3729LEUH-6#TRPBF — Даташит
Серия | LTC3729L-6 |
Модель | LTC3729LEUH-6#TRPBF |
PolyPhase, синхронный понижающий импульсный регулятор
Datasheet LTC3729L-6
PDF, 356 Кб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 28
PolyPhase, Synchronous Step-Down Switching Regulator
12 предложений от 11 поставщиков , PolyPhase, Synchronous Step-Down Switching Regulator | |||
LTC3729LEUH-6#TRPBF Analog Devices | 243 ₽ | ||
LTC3729LEUH-6#TRPBF Analog Devices | 182 301 ₽ | ||
LTC3729LEUH-6#TRPBF Linear Technology | по запросу | ||
LTC3729LEUH-6#TRPBF | по запросу |
Корпус | 5x5 QFN-32 |
Код корпуса | UH |
Индекс корпуса | 05-08-1693 |
Архитектура | Constant Frequency Current Mode |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | PolyPhase |
Тактовая частота | 550 kHz |
Integrated Inductor | нет |
Ishutdown | 20 мкА |
Isupply | 0.47 мА |
Max Phases | 2, 3, 4, 6, 8, 12 |
Monolithic | нет |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 85 °C |
Выходной ток | 40 A |
Polyphase | да |
Sense Resistor | Rsense |
Switch Current | 40 A |
Synchronous | да |
Topology | Buck |
Vin Max | 30 В |
Vin Min | 4 В |
Vout Max | 5 В |
Vout Maximum | 5V |
Vout Min | 0.6 В |
Vref Accuracy Over Temp | 1 % |
- PCB Layout Considerations for Non-Isolated Switching Power Supplies &mdash AN136PDF, 215 Кб, Файл опубликован: 20 сен 2012
The best news when you power up a prototype supply board for the very first time is when it not only works, but also runs quiet and cool. Unfortunately, this does not always happen. A common problem of switching power supplies is “unstable” switching waveforms. Sometimes, waveform jittering is so pronounced that audible noise can be heard from the magnetic components. If the problem is related to the printed circuit board (PCB) layout, identifying the cause can be difficult. This is why proper PCB layout at the early stage of a switching supply design is very critical. Its importance cannot be overstated.Выписка из документа
Серия: LTC3729L-6 (2)
- LTC3729LEUH-6#PBF LTC3729LEUH-6#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC3729LEUH-6TRPBF, LTC3729LEUH-6 TRPBF, LTC3729LEUH6#TRPBF, LTC3729LEUH 6#TRPBF
