Datasheet Linear Technology LTC3829IFE#TRPBF — Даташит
СерияLTC3829
МодельLTC3829IFE#TRPBF
3-фазный синхронный понижающий регулятор постоянного / понижающего напряжения с одним выходом и диффузором
LTC3829 - 3-Phase, Single Output Synchronous Step-Down DC/DC Controller with Diffamp
PDF, 437 Кб, Версия: D, Файл закачен: 27 мар 2018
IC REG CTRLR BUCK 38TSSOP. Buck Regulator Positive Output Step-Down DC-DC Controller IC 38-TSSOP-EP. PMIC - Voltage Regulators - DC DC...
LTC3829IFE#TRPBF
417 ₽
LTC3829IFE#TRPBF
467 ₽
LTC3829IFE#TRPBF
LTC3829IFE#TRPBF
КорпусTSSOP-38
Код корпусаFE
Индекс корпуса05-08-1772
АрхитектураConstant Frequency Current Mode
Demo BoardsDC1530A,DC1675A
Design ToolsLTspice File,LTpowerCAD File
Экспортный контрольнет
Основные особенностиBurst Mode, Differential Remote Sense, Phase Shedding, DCR Current Sense, Active Voltage Positioning, External Synchronization, Resistor Set Frequency, Nonlinear Control
Тактовая частота770 kHz
Frequency Adjust Range250kHz - 770kHz
Frequency Sync Range250kHz - 770kHz
Integrated Inductorнет
Ishutdown40 мкА
Isupply4 мА
Max Phases3, 6
Monolithicнет
Количество выходов1
Выходной ток90 A
Polyphaseда
Sense ResistorRsense, DCR
Switch Current90 A
Synchronousда
TopologyBuck
Vin Max38 В
Vin Min4.5 В
Vout Max5 В
Vout Maximum5V
Vout Min0.6 В
Vref Accuracy Over Temp0.75 %
  • A Closed-Loop, Wideband, 100A Active Load &mdash AN133
    PDF, 1.3 Мб, Файл опубликован: 12 окт 2011
    Digital systems, particularly microprocessors, furnish transient loads in the 100A range that a voltage regulator must service. Ideally, regulator output is invariant during a load transient. In practice, some variation is encountered and becomes problematic if allowable operating voltage tolerances are exceeded. 100A load steps, characteristic of microprocessors, exacerbate this issue, necessitating testing the regulator and associated components under such transient loading conditions. To meet this need, a closed-loop, 500kHz bandwidth, linearly responding, 100A capacity active load is described in this document.
  • Basic Concepts of Linear Regulator and Switching Mode Power Supplies &mdash AN140
    PDF, 715 Кб, Файл опубликован: 1 окт 2013
Design Notes
  • High Efficiency, High Density 3-Phase Supply Delivers 60A with Power Saving Stage Shedding, Active Voltage Positioning and Nonlinear Control for Superior Load Step Response &mdash DN489
    PDF, 100 Кб, Файл опубликован: 18 мар 2011
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC3829IFETRPBF, LTC3829IFE TRPBF
На английском языке: Datasheet Linear Technology LTC3829IFE#TRPBF
Публикации по теме
