Datasheet Linear Technology LTC3855IUJ#TRPBF — Даташит
| Серия | LTC3855 |
| Модель | LTC3855IUJ#TRPBF |
Двойной, многофазный синхронный контроллер постоянного / постоянного тока с дифференциальным дистанционным датчиком
Datasheet LTC3855
PDF, 2.2 Мб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 44
Dual, Multiphase Synchronous DC/DC Controller with Differential Remote Sense
- PCB Layout Considerations for Non-Isolated Switching Power Supplies &mdash AN136PDF, 215 Кб, Файл опубликован: 20 сен 2012
The best news when you power up a prototype supply board for the very first time is when it not only works, but also runs quiet and cool. Unfortunately, this does not always happen. A common problem of switching power supplies is “unstable” switching waveforms. Sometimes, waveform jittering is so pronounced that audible noise can be heard from the magnetic components. If the problem is related to the printed circuit board (PCB) layout, identifying the cause can be difficult. This is why proper PCB layout at the early stage of a switching supply design is very critical. Its importance cannot be overstated.Выписка из документа - Modeling and Loop Compensation Design of Switching Mode Power Supplies &mdash AN149PDF, 1.4 Мб, Файл опубликован: 23 мар 2015Выписка из документа
Design Notes
- Dual Output Step-Down Controller Produces Accurate, Efficient and Reliable High Current Rails &mdash DN478PDF, 84 Кб, Файл опубликован: 23 мар 2010Выписка из документа
Статьи
- 6mm × 6mm DC/DC Controller for High Current DCR Sensing Applications &mdash LT JournalPDF, 494 Кб, Файл опубликован: 1 апр 2010Выписка из документа
Серия: LTC3855 (8)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | External Power Switch Buck Controllers
LTC3855IUJTRPBF, LTC3855IUJ TRPBF
