Datasheet Linear Technology LTM8022EV#PBF — Даташит
Серия | LTM8022 |
Модель | LTM8022EV#PBF |
1A, 36В DC/DC µModule (Модуль питания)
Datasheet LTM8022
PDF, 283 Кб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 20
1A, 36V DC/DC µModule
![]() 34 предложений от 16 поставщиков Преобразователь DC/DC, Conv DC-DC 3.6V to 36V Step Down Single-Out 0.8V to 10V 1A uModule Automotive 50Pin LGA | |||
LTM8022EV#PBF Analog Devices | от 296 ₽ | ||
LTM8022EV#PBF Linear Technology | 653 ₽ | ||
LTM8022EV#PBF Analog Devices | от 747 ₽ | ||
LTM8022EV#PBF Analog Devices | от 2 549 ₽ |
Корпус | 11.25mm × 9mm × 2.82mm LGA |
Код корпуса | LGA |
Индекс корпуса | 05-08-1804 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC1261A |
Design Tools | LTspice File,LTpowerCAD Model |
Экспортный контроль | нет |
Основные особенности | Resistor Set Frequency, External Synchronization, Power Good, PolyPhase |
Тактовая частота | 2400 kHz |
Frequency Adjust Range | 200kHz - 2.4MHz |
Frequency Sync Range | 250kHz - 2MHz |
Integrated Inductor | да |
Ishutdown | 1 мкА |
Isupply | 0.085 мА |
Max Phases | 2 |
Monolithic | да |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 85 °C |
Выходной ток | 1 A |
Polyphase | да |
Switch Current | 2 A |
Synchronous | нет |
Topology | Buck |
Topology 1 | Buck |
Vin Max | 36 В |
Vin Min | 3.6 В |
Vout Max | 10 В |
Vout Maximum | 10V |
Vout Min | 0.8 В |
- DC/DC uModule Regulator Printed Circuit Board Design Guidelines &mdash AN117PDF, 91 Кб, Файл опубликован: 23 апр 2008
The LTM8020, LTM8021, LTM8022 and LTM8023 μModules are complete easy-to-use encapsulated step down DC/DC regulators intended to take the pain and aggravation out of implementing a switching power supply onto a system board. With a μModule, you only need an input cap, output cap and one or two resistors to complete the design. As one might imagine, this high level of integration greatly simpliп¬Ѓes the task of printed circuit board design, reducing the effort to four categories: component footprint generation, component placement, routing the nets, and thermal vias.Выписка из документа
Design Notes
- How to Produce Negative Output Voltages from Positive Inputs Using a uModule Step-Down Regulator &mdash DN1021PDF, 120 Кб, Файл опубликован: 24 май 2011Выписка из документа
Статьи
- uModule Regulators Shrink Power Supply Size and Design Effort &mdash LT JournalPDF, 240 Кб, Файл опубликован: 14 янв 2008Выписка из документа
Серия: LTM8022 (3)
- LTM8022EV#PBF LTM8022IV#PBF LTM8022MPV#PBF
- µModule Solutions > µModule Regulators > µModule Buck Regulators | Extended Temperature (H & MP) µModule Regulators
LTM8022EVPBF, LTM8022EV PBF
