Datasheet Linear Technology LTM8052 — Даташит
СерияLTM8052
36VIN, 5A, 2-квадрантный понижающий микромодуль CVCC (силовой модуль) регулятор
Datasheet LTM8052, LTM8052A
PDF, 640 Кб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 32
36VIN, 5A, 2-Quadrant CVCC Step-Down μModule Regulator
35 предложений от 19 поставщиков
Преобразователь DC/DC, LINEAR TECHNOLOGY LTM8052EV#PBF DC-DC POL Converter, Adjustable, Buck, 1MHz, 1.2V to 24V out, 5A, LGA-81
Microfind
LTM8052EV#PBF
3 607 ₽
LTM8052EV#PBF
от 4 657 ₽
727GS
LTM8052MPV#PBF
LTM8052AIV#PBF
LTM8052EV#PBFLTM8052EY#PBFLTM8052IV#PBFLTM8052IYLTM8052IY#PBFLTM8052MPV#PBFLTM8052MPYLTM8052MPY#PBF
N12345678
Корпус15mm x 11.25mm x 2.82mm LGA
Габаритный чертеж корпуса
15mm x 11.25mm x 3.42mm BGA
Код корпусаLGABGALGABGABGALGABGABGA
Индекс корпуса05-08-186805-08-195905-08-186805-08-195905-08-195905-08-186805-08-195905-08-1959
Количество выводов8181818181818181
Parameters / ModelsLTM8052EV#PBFLTM8052EY#PBFLTM8052IV#PBFLTM8052IYLTM8052IY#PBFLTM8052MPV#PBFLTM8052MPYLTM8052MPY#PBF
Buck Output Current, AВ±5AВ±5AВ±5AВ±5AВ±5AВ±5AВ±5AВ±5A
Charge TerminationMicrocontrollerMicrocontrollerMicrocontrollerMicrocontrollerMicrocontrollerMicrocontrollerMicrocontrollerMicrocontroller
Demo BoardsDC1939A,DC1866ADC1939A,DC1866ADC1939A,DC1866ADC1939A,DC1866ADC1939A,DC1866ADC1939A,DC1866ADC1939A,DC1866ADC1939A,DC1866A
Design ToolsLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice File
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиResistor Set Frequency, External Synchronization, Output Current RegulationResistor Set Frequency, External Synchronization, Output Current RegulationResistor Set Frequency, External Synchronization, Output Current RegulationResistor Set Frequency, External Synchronization, Output Current RegulationResistor Set Frequency, External Synchronization, Output Current RegulationResistor Set Frequency, External Synchronization, Output Current RegulationResistor Set Frequency, External Synchronization, Output Current RegulationResistor Set Frequency, External Synchronization, Output Current Regulation
Float Voltage, ВUp to 24VUp to 24VUp to 24VUp to 24VUp to 24VUp to 24VUp to 24VUp to 24V
Max Charge Current, A55555555
Number of CellsUp to 24V float voltageUp to 24V float voltageUp to 24V float voltageUp to 24V float voltageUp to 24V float voltageUp to 24V float voltageUp to 24V float voltageUp to 24V float voltage
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125от -55 до 125
SubnameLTM8052LTM8052LTM8052LTM8052LTM8052LTM8052LTM8052LTM8052
Type of ChargerSwitchingSwitchingSwitchingSwitchingSwitchingSwitchingSwitchingSwitching
Vin Max, В3636363636363636
Vin Min, В66666666
RoHSСовместимСовместимСовместимНе совместимСовместимСовместимНе совместимСовместим
LTM8052A LTM8052A
  • µModule Solutions > µModule Regulators > µModule Buck Regulators | Extended Temperature (H & MP) µModule Regulators
  • Power Management > Supercapacitor Chargers
  • Power Management > Battery Management > Battery Charger IC > µModule Battery Chargers
На английском языке: Datasheet Linear Technology LTM8052
Публикации по теме
