Datasheet IRFZ34NPBF - International Rectifier Даташит Полевой транзистор, N, 55 В, 26 А, TO-220 — Даташит
Наименование модели: IRFZ34NPBF
![]() 57 предложений от 23 поставщиков Силовой МОП-транзистор, N Канал, 55 В, 29 А, 0.04 Ом, TO-220AB, Through Hole | |||
IRFZ34NPBF Infineon | от 31 ₽ | ||
IRFZ34NPBF Infineon | 51 ₽ | ||
IRFZ34NPBF/IR International Rectifier | по запросу | ||
IRFZ34NPBF Infineon | по запросу |
Описание: Полевой транзистор, N, 55 В, 26 А, TO-220
PD - 94807
IRFZ34NPbF
HEXFET® Power MOSFET
Advanced Process Technology Ultra Low On-Resistance Dynamic dv/dt Rating 175°C Operating Temperature Fast Switching Ease of Paralleling Lead-Free Description
Fifth Generation HEXFETs from International Rectifier utilize advanced processing techniques to achieve the lowest possible on-resistance per silicon area.
This benefit, combined with the fast switching speed and ruggedized device design that HEXFET Power MOSFETs are well known for, provides the designer with an extremely efficient device for use in a wide variety of applications. The TO-220 package is universally preferred for all commercial-industrial applications at power dissipation levels to approximately 50 watts. The low thermal resistance and low package cost of the TO-220 contribute to its wide acceptance throughout the industry. TO-220AB
- Continuous Drain Current Id: 26 А
- Drain Source Voltage Vds: 55 В
- On Resistance Rds(on): 40 МОм
- Voltage Vgs Max: 4 В
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 29 А
- Current Temperature: 25°C
- Маркировка: IRFZ34NPBF
- Тепловое сопротивление переход-корпус: 2.7°C/W
- Расстояние между выводами: 2.54 мм
- Количество транзисторов: 1
- Тип корпуса: TO-220AB
- Pin Format: 1 г
- Power Dissipation Pd: 56 Вт
- Pulse Current Idm: 100 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 4 В
- Voltage Vds Typ: 55 В
- Voltage Vgs Rds on Measurement: 10 В
Дополнительные аксессуары:
- Fischer Elektronik - SK 145/37,5 STS-220
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
- Fischer Elektronik - WLK 5
