Datasheet Linear Technology LTC1262IS8#TRPBF — Даташит
| Серия | LTC1262 |
| Модель | LTC1262IS8#TRPBF |
Блок питания для программирования флэш-памяти 12 В, 30 мА
LTC1262 - 12V, 30mA Flash Memory Programming Supply
PDF, 209 Кб, Версия: A, Файл закачен: 27 сен 2017
|  Купить LTC1262IS8#TRPBF на РадиоЛоцман.Цены — от 118 до 1 001 ₽ 14 предложений от 14 поставщиков IC REG CONV PROG SUP 1OUT 8SOIC. - Converter, Programming Supply Voltage Regulator IC 1 Output 8-SOIC. PMIC - Voltage Regulators... | |||
| LTC1262IS8#TRPBF Analog Devices | 118 ₽ | ||
| LTC1262IS8#TRPBF Analog Devices | 190 ₽ | ||
| LTC1262IS8#TRPBF Linear Technology | 235 ₽ | ||
| LTC1262IS8#TRPBF Analog Devices | по запросу | ||
| Корпус | SO-8 |
| Код корпуса | S8 |
| Индекс корпуса | 05-08-1610 (S8) |
| Design Tools | LTspice Model |
| Экспортный контроль | нет |
| Тактовая частота | 300 kHz |
| Function | Flash Memory Programming, Regulated Step-Up Charge Pump |
| Ishutdown | 1 мкА |
| Isupply | 0.5 мА |
| Количество выходов | 1 |
| Выходной ток | 0.03 A |
| Выходное напряжение | 12V |
| Vin Max | 5 В |
| Vin Min | 5 В |
- Linear Technology Magazine Circuit Collection, Volume II &mdash AN66PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
 Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.Выписка из документа
Design Notes
- Flash Memory VPP Generator Reference Designs &mdash DN97PDF, 124 Кб, Файл опубликован: 1 фев 1995Выписка из документа
Серия: LTC1262 (5)
- LTC1262CN8#PBF LTC1262CS8#PBF LTC1262CS8#TRPBF LTC1262IS8#PBF LTC1262IS8#TRPBF
- Power Management > Inductorless (Charge Pump) DC/DC Converters > Flash Memory Programming | Regulated Step-Up Charge Pumps
LTC1262IS8TRPBF, LTC1262IS8 TRPBF
