Datasheet Linear Technology LTC3220EPF#PBF — Даташит
Серия | LTC3220 |
Модель | LTC3220EPF#PBF |
Универсальный 18-канальный светодиодный драйвер 360 мА
LTC3220/LTC3220-1 - 360mA Universal 18-Channel LED Driver
PDF, 279 Кб, Версия: D, Файл закачен: 27 сен 2017
![]() 36 предложений от 20 поставщиков Драйвер LED , LINEAR TECHNOLOGY LTC3220EPF-1#PBF LED Driver, Charge Pump, 2.9V to 5.5V input, 18Outputs, 850kHz switch-freq., 360mA out, TQFN-28 | |||
LTC3220EPF TRPBF Linear Technology | по запросу | ||
LTC3220EPF#TRPBF Analog Devices | по запросу | ||
LTC3220EPF-TRPBF | по запросу | ||
LTC3220EPF-PBF | по запросу |
Корпус | 4x4 UTQFN-28 |
Код корпуса | PF |
Индекс корпуса | 05-08-1759 |
Demo Boards | DC1265A-A,DC1265A-B |
Экспортный контроль | нет |
Основные особенности | I2C Control |
Тактовая частота | 850 kHz |
Ishutdown | 3.2 мкА |
Isupply | .580 мА |
Max Number of LEDs | 18 (parallel) |
Monolithic | да |
Количество выходов | 18 |
Рабочий диапазон температур | от 0 до 85 °C |
Выходной ток | 0.36 A |
Synchronous | нет |
Topology | Charge Pump, LED Driver |
Vin Max | 5.5 В |
Vin Min | 2.9 В |
Vout Max | 5.5 В |
- LTC3220/LTC3220-1 User’s Guide &mdash AN115PDF, 224 Кб, Файл опубликован: 28 фев 2008
This application note illustrates how to program and use the unique features of the LTC3220/LTC3220-1 Universal LED (ULED) Driver. These features include individually controlling, gradually turning on and off, or blinking up to 18 LEDs. This device may also be used to provide digital signal(s) to other devices while in shutdown using a strong pull-down general purpose output (GPO) and an external power source. Current limited GPO mode may also be used to control other devices using the charge pump output (CPO) of the device or an external supply. A programmable shutdown feature allows the device to go into and out of shutdown returning to its pre-shutdown state. These features give the user vast flexibility and control of LEDs and other devices while saving memory space, programming time, I2C trafп¬Ѓc, and even battery power.Выписка из документа
Серия: LTC3220 (4)
- LTC3220EPF#PBF LTC3220EPF#TRPBF LTC3220IPF#PBF LTC3220IPF#TRPBF
- Power Management > Inductorless (Charge Pump) DC/DC Converters > Inductorless (Charge Pump) LED Drivers
LTC3220EPFPBF, LTC3220EPF PBF
