Datasheet Linear Technology LTC3220IPF#PBF — Даташит
СерияLTC3220
МодельLTC3220IPF#PBF
Универсальный 18-канальный светодиодный драйвер 360 мА
LTC3220/LTC3220-1 - 360mA Universal 18-Channel LED Driver
PDF, 279 Кб, Версия: D, Файл закачен: 27 сен 2017
36 предложений от 19 поставщиков
IC LED DRIVER RGLTR 20MA 28UTQFN / LED Driver 18 Segment 3200uA Supply Current 28-Pin UTQFN EP Tube
LTC3220IPF-1#PBF
от 117 ₽
LTC3220IPF#PBF
211 ₽
ЗУМ-СМД
LTC3220IPF
LTC3220IPF-1-TRPBF
Корпус4x4 UTQFN-28
Код корпусаPF
Индекс корпуса05-08-1759
Demo BoardsDC1265A-A,DC1265A-B
Экспортный контрольнет
Основные особенностиI2C Control
Тактовая частота850 kHz
Ishutdown3.2 мкА
Isupply.580 мА
Max Number of LEDs18 (parallel)
Monolithicда
Количество выходов18
Выходной ток0.36 A
Synchronousнет
TopologyCharge Pump, LED Driver
Vin Max5.5 В
Vin Min2.9 В
Vout Max5.5 В
LTC3220-1
  • LTC3220/LTC3220-1 User’s Guide &mdash AN115
    PDF, 224 Кб, Файл опубликован: 28 фев 2008
    This application note illustrates how to program and use the unique features of the LTC3220/LTC3220-1 Universal LED (ULED) Driver. These features include individually controlling, gradually turning on and off, or blinking up to 18 LEDs. This device may also be used to provide digital signal(s) to other devices while in shutdown using a strong pull-down general purpose output (GPO) and an external power source. Current limited GPO mode may also be used to control other devices using the charge pump output (CPO) of the device or an external supply. A programmable shutdown feature allows the device to go into and out of shutdown returning to its pre-shutdown state. These features give the user vast flexibility and control of LEDs and other devices while saving memory space, programming time, I2C traffic, and even battery power.
  • Power Management > Inductorless (Charge Pump) DC/DC Converters > Inductorless (Charge Pump) LED Drivers
LTC3220IPFPBF, LTC3220IPF PBF
На английском языке: Datasheet Linear Technology LTC3220IPF#PBF
