Datasheet Texas Instruments BQ25700ARSNR — Даташит
Серия | BQ25700A |
Модель | BQ25700ARSNR |
Контроллер понижающе-повышающего заряда аккумулятора NVDC SMBus с монитором питания системы и процессором 32-QFN от -40 до 85
bq25700A SMBus Multi-Chemistry Battery Buck-Boost Charge Controller With System Power Monitor and Processor Hot Monitor datasheet
PDF, 1.7 Мб, Файл опубликован: 17 май 2017
Pin | 32 | 32 |
Package Type | RSN | RSN |
Industry STD Term | WQFN | WQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | BQ | 25700A |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .75 | .75 |
Pitch (мм) | .4 | .4 |
Max Height (мм) | .8 | .8 |
Absolute Vin (safety rating)(Max)( | 30 В |
Battery Charge Voltage(Max) | 19.2 В |
Battery Charge Voltage(Min) | 1.024 В |
Cell Chemistry | Lead Acid,Li-Ion/Li-Polymer,LiFePO4,Lithium phosphate,NiCd,NiMH,SuperCap |
Charge Current(Max) | 8.128 A |
Control Interface | SMBus |
Control Topology | Switch-Mode Buck-boost |
Number of Series Cells | 1,2,3,4 |
Operating Vin(Max) | 24 В |
Operating Vin(Min) | 3.5 В |
Package Group | QFN |
Package Size: mm2:W x L | 32QFN: 16 mm2: 4 x 4(QFN) PKG |
Special Features | 1-4 Cells,Integrated ADC,OTG (On The Go Boost),Over Voltage Protection,Power Path,Solar Input,Standard BAT Temp Monitoring,Thermal Regulation,Under Voltage Protection,Vin DPM (OK for Solar Power Source) |
USB Feature | USB OTG,USB Source,USB-Friendly |
- Evaluation Modules & Boards: BQ25700AEVM-732
bq25700A SMBus NVDC Buck-boost Charger Evaluation Module
- Layout Guidelines for the bq2570x Switching ChargerPDF, 244 Кб, Файл опубликован: 19 май 2017
Серия: BQ25700A (2)
- BQ25700ARSNR BQ25700ARSNT
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
