Datasheet Texas Instruments 5962-89957012A — Даташит
СерияUC1637
Модель5962-89957012A
Контроллер переключаемого режима для привода двигателя постоянного тока 20-LCCC от -55 до 125
Switched Mode Controller for DC Motor Drive datasheet
PDF, 902 Кб, Файл опубликован: 5 сен 1999
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Основные особенностиCurrent-Limited,DC Motor Control,Switching Control
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
RoHSSee ti.com
  • U-120 A Simplified Approach to DC Motor Modeling for Dynamic Stability Analysis
    PDF, 106 Кб, Файл опубликован: 5 сен 1999
    When we say that an electric motor is a device that transforms electric power into mechanical power we say two things. First that the motor is ?and behaves as ?a transformer. Second that it stands at the dividing line between electrical and mechanical phenomena. In the case of permanent magnet motors this power transformation works in both directions so that the electrical impedance depends on
Серия: UC1637 (6)
  • Semiconductors > Space & High Reliability > Power Management Products > Power Management Special Function Products
596289957012A, 5962 89957012A
На английском языке: Datasheet Texas Instruments 5962-89957012A
