Datasheet Texas Instruments BQ24100RHLRG4 — Даташит
СерияBQ24100
МодельBQ24100RHLRG4
Автономное синхронное импульсное литий-ионное зарядное устройство с полевым транзистором 2 А в QFN-20, 1-элементный 20-VQFN от -40 до 85
bq241xx Synchronous Switched-Mode, Li-Ion and Li-Polymer Charge-Management IC With Integrated Power FETs (bqSWITCHERв„ў) datasheet
PDF, 1.5 Мб, Версия: P, Файл опубликован: 30 ноя 2015
Микросхема Чип управления батареи, Switch Mode Charger Li-Ion/Li-Pol/NiCD/NiMH 150mA to 2000mA 4.2V 20Pin VQFN EP T/R
BQ24100RHLRG4
125 ₽
Рутоника
BQ24100RHLRG4
183 ₽
BQ24100RHLRG4
251 ₽
Hi-Tech Circuit Group
BQ24100RHLRG4
Pin20
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаCIA
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Absolute Vin (safety rating)(Max)(20 В
Battery Charge Voltage(Max)4.2 В
Battery Charge Voltage(Min)4.2 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1
Operating Vin(Max)16 В
Operating Vin(Min)4.35 В
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 16 mm2: 3.5 x 4.5(VQFN) PKG
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24100EVM
    BQ24100 Evaluation Module
  • Power Dissipation Analysis & Circuit Design for Sync Switching Battery Charger
    PDF, 402 Кб, Файл опубликован: 31 май 2005
    The bqSWITCHER(TM) (bq24100/03/05/08/13/15) is a highly integrated, switch-mode, Li-ion and Li-polymer battery charger IC. With two power MOSFETs, the gate drivers, and the controller fully integrated in the chip, the circuit design as well as the PCB layout has been appreciably simplified. However, it is still important to have a good understanding of the charger circuit design, layout principles
  • Extending Single Input Charger to Dual Input Applications (Rev. A)
    PDF, 256 Кб, Версия: A, Файл опубликован: 21 сен 2009
  • Implementations of Battery Charger and Power-Path Mgmt System Using bq241xx
    PDF, 752 Кб, Файл опубликован: 6 июн 2006
    This application report presents four system topologies that can be used to fully implement a portable power management system solution using the bqSWITCHERв„ў. Test results and the advantages and issues of each topology are discussed.
  • Drive High Current LEDs
    PDF, 437 Кб, Файл опубликован: 25 янв 2007
    This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
Серия: BQ24100 (3)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24100RHLRG4
