Datasheet Linear Technology LT1510-5IGN#PBF — Даташит
СерияLT1510
МодельLT1510-5IGN#PBF
Constant-Voltage/Constant-Current Battery Charger
Datasheet LT1510, LT1510-5
PDF, 297 Кб, Язык: анг., Файл закачен: 2 окт 2017, Страниц: 16
Микросхема Чип управления батареи, Battery Charger Li-Ion/NiCD/NiMH 1500mA 2V to 20V 16Pin SSOP N
LT1510-5IGN
403 ₽
LT1510-5IGN
LT1510-5IGN TRPBF
LT1510-5IGN.
КорпусSSOP-16
Код корпусаGN
Индекс корпуса05-08-1641 (GN16)
Battery ChemistryLi-Ion, Li-Polymer, NiCd, NiMH, Lead Acid
Charge TerminationUse LTC1729
Demo BoardsDC086A,DC179A,DC294A-B,DC294A-D
Design ToolsLTspice File
Экспортный контрольнет
Float VoltageAdj В
Internal Pass Elementнет
Max Charge Current1 A
Number of Cells1 to 4 (Li), 1 to 12 (Ni)
Type of ChargerSwitching
Vin Max29 В
Vin Min7 В
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
  • LT1510 Design Manual &mdash AN68
    PDF, 377 Кб, Файл опубликован: 30 дек 1996
    The ever-growing popularity of portable equipment in recent years has pushed battery technologists to search for battery types that store more energy in a smaller volume, weigh less and are safer. Also, the power source selection for charging the batteries has diversified. For example, a notebook computer can be connected to a car battery, a power adapter, a docking station or even to solar cells. The variety of input voltages, coupled with the need for high efficiency and the need for accurate constant voltage and constant current, as in the case of Li-Ion batteries (see below), have led to the introduction of a switching type constant-voltage, constant-current battery charger IC, the LT®1510.
Design Notes
  • LT1510 High Efficiency Lithium-Ion Battery Charger &mdash DN111
    PDF, 77 Кб, Файл опубликован: 1 сен 1995
  • New Battery Charger ICs Need No Heat Sinks &mdash DN124
    PDF, 75 Кб, Файл опубликован: 1 мар 1996
  • Inexpensive Circuit Charges Lithium-Ion Cells &mdash DN188
    PDF, 72 Кб, Файл опубликован: 1 сен 1998
  • Li-Ion Charge Termination IC Interfaces with PWM Switchers &mdash DN242
    PDF, 74 Кб, Файл опубликован: 2 окт 2001
  • Power Management > Battery Management > Battery Charger IC > Switching Battery Chargers
LT1510-5IGNPBF, LT1510-5IGN PBF, LT15105IGN#PBF, LT1510 5IGN#PBF
На английском языке: Datasheet Linear Technology LT1510-5IGN#PBF
Публикации по теме
