Datasheet Linear Technology LT1511CSW#TRPBF — Даташит
Серия | LT1511 |
Модель | LT1511CSW#TRPBF |
Constant-Current/ Constant-Voltage 3A Battery Charger with Input Current Limiting
Datasheet LT1511
PDF, 149 Кб, Язык: анг., Файл закачен: 2 окт 2017, Страниц: 16
Constant-Current/Constant-Voltage 3A Battery Charger with Input Current Limiting
![]() 14 предложений от 12 поставщиков Микросхема Чип управления батареи, Battery Charger Li-Ion/NiCD/NiMH 3000mA 1V to 20V 24Pin SOIC W T/R | |||
LT1511CSW#TRPBF Linear Technology | 542 ₽ | ||
LT1511CSW#TRPBF Linear Technology | по запросу | ||
LT1511CSW-4#TRPBF Linear Technology | по запросу |
Корпус | SW-24 |
Код корпуса | SW |
Индекс корпуса | 05-08-1620 (SW24) |
Battery Chemistry | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid |
Charge Termination | Use LTC1729 |
Demo Boards | DC103A |
Экспортный контроль | нет |
Float Voltage | Adj В |
Internal Pass Element | да |
Max Charge Current | 3 A |
Number of Cells | 1 to 4 (Li), 1 to 12 (Ni) |
Рабочий диапазон температур | от 0 до 70 °C |
Type of Charger | Switching |
Vin Max | 29 В |
Vin Min | 7 В |
- Linear Technology Magazine Circuit Collection, Volume III &mdash AN67PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.Выписка из документа - Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.Выписка из документа
Design Notes
- New Battery Charger ICs Need No Heat Sinks &mdash DN124PDF, 75 Кб, Файл опубликован: 1 мар 1996Выписка из документа
- LT1511 Low Dropout, Constant-Current/Constant-Voltage 3A Battery Charger &mdash DN144PDF, 80 Кб, Файл опубликован: 2 дек 1996Выписка из документа
- Inexpensive Circuit Charges Lithium-Ion Cells &mdash DN188PDF, 72 Кб, Файл опубликован: 1 сен 1998Выписка из документа
- New Charger Topology Maximizes Battery Charging Speed &mdash DN194PDF, 96 Кб, Файл опубликован: 2 ноя 1998Выписка из документа
- Li-Ion Charge Termination IC Interfaces with PWM Switchers &mdash DN242PDF, 74 Кб, Файл опубликован: 2 окт 2001Выписка из документа
Серия: LT1511 (4)
- LT1511CSW#PBF LT1511CSW#TRPBF LT1511ISW#PBF LT1511ISW#TRPBF
- Power Management > Battery Management > Battery Charger IC > Switching Battery Chargers
LT1511CSWTRPBF, LT1511CSW TRPBF
