Datasheet Linear Technology LT1513-2IR#PBF — Даташит
Серия | LT1513-2 |
Модель | LT1513-2IR#PBF |
SEPIC Constant- or Programmable-Current/Constant-Voltage Battery Charger
Datasheet LT1513, LT1513-2
PDF, 220 Кб, Язык: анг., Файл закачен: 2 окт 2017, Страниц: 16
![]() 14 предложений от 14 поставщиков Микросхема Чип управления батареи, Battery Charger Lead-Acid/Li-Ion/NiCD/NiMH 2000mA 20V 8Pin(7+Tab) DDPAK | |||
LT1513-2IR Analog Devices | 336 ₽ | ||
LT1513-2IR Linear Technology | 428 ₽ | ||
LT1513-2IR Linear Technology | по запросу | ||
LT1513-2IR | по запросу |
Корпус | DDPAK-7 |
Код корпуса | R |
Индекс корпуса | 05-08-1462 |
Battery Chemistry | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid |
Charge Termination | External |
Design Tools | LTspice File |
Экспортный контроль | нет |
Float Voltage | Adj В |
Internal Pass Element | да |
Max Charge Current | 2 A |
Number of Cells | 1 to 4 (Li), 1 to 18 (Ni) |
Type of Charger | Switching, Buck-Boost |
Vin Max | 29 В |
Vin Min | 2.4 В |
- Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.Выписка из документа
Design Notes
- Low Input Voltage CCFL Power Supply &mdash DN133PDF, 75 Кб, Файл опубликован: 2 июл 1996Выписка из документа
- Li-Ion Charge Termination IC Interfaces with PWM Switchers &mdash DN242PDF, 74 Кб, Файл опубликован: 2 окт 2001Выписка из документа
Серия: LT1513-2 (6)
- LT1513-2CR#PBF LT1513-2CR#TRPBF LT1513-2CT7#PBF LT1513-2IR#PBF LT1513-2IR#TRPBF LT1513-2IT7#PBF
- Power Management > Battery Management > Battery Charger IC > Switching Battery Chargers | Buck/Boost Battery Chargers
LT1513-2IRPBF, LT1513-2IR PBF, LT15132IR#PBF, LT1513 2IR#PBF
