Оптопары и оптореле Megawin
Datasheet Linear Technology LTC3880IUJ-1#PBF — Даташит
СерияLTC3880
МодельLTC3880IUJ-1#PBF
Dual Output PolyPhase Step-Down DC/DC Controller with Digital Power System Management
LTC3880/LTC3880-1: Dual Output PolyPhase Step-Down DC/DC Controller with Digital Power System Management Data Sheet
PDF, 1.7 Мб, Файл закачен: 24 сен 2017
30 предложений от 18 поставщиков
Интегральные микросхемы Силовые чипы — регуляторы напряжения — постоянного тока коммутирующие контроллеры
LTC3880IUJ-1#PBF
500 ₽
Эиком
LTC3880IUJ-1#PBF
от 1 866 ₽
727GS
LTC3880IUJ-1#PBF
ЗУМ-СМД
LTC3880IUJ-1
Корпус6x6 QFN-40
Код корпусаUJ
Индекс корпуса05-08-1728
ADC16-Bit
DAC12-Bit
Demo BoardsDC1590B-B,DC1590B-A,DC1753A-A,DC1709A,DC1962C,DC2052A,DC1740A-A,DC1740A-B,DC1962C-KIT,DC2088A,DC2089A-A,DC2089A-B,DC1753B-A,DC1753B-B
Design ToolsLTspice File,LTpowerCAD File,LTpowerPlay ,Linduino File
Экспортный контрольнет
Основные особенностиBurst Mode, Differential Remote Sense, PolyPhase, PMBus, I2C Control, EEPROM, ADC, DCR Current Sense, Sequencing, Margining, Tracking, External Synchronization
FunctionDC/DC Regulator With Power System Management
I/OPMBus/SMBus/I2C
Isupply20 мА
MonitorsVin, Iin, Vout, Iout, Temperature and Faults
Количество выходов2
Диапазон напряжения питания4.5V to 24V
Vin Max24 В
Vin Min4.5 В
  • Implementing Robust PMBus System Software for the LTC3880 &mdash AN135
    PDF, 126 Кб, Файл опубликован: 6 апр 2012
    The LTC3880 is a dual output PolyPhase step-down DC/DC controller with integrated digital power system management. The LTC3880 can easily be controlled through a PMBus interface, which builds upon I2C/IIC at speeds up to 400kHz. System telemetry data can be obtained quickly and painlessly with simple polling functions. This exposes all important and critical information to the system developer such as the voltage and current readings for the input and both outputs, temperature, fault conditions, general status information, and more.
  • Accurate Temperature Sensing with an External P-N Junction &mdash AN137
    PDF, 540 Кб, Файл опубликован: 20 сен 2012
    Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.
  • Overview of the EEPROM in LTC PSM Devices &mdash AN145
    PDF, 3.0 Мб, Файл опубликован: 10 май 2014
  • Power System Management Addressing &mdash AN152
    PDF, 169 Кб, Файл опубликован: 12 июл 2016
  • Linduino for Power System Management &mdash AN153
    PDF, 1.3 Мб, Файл опубликован: 24 фев 2016
  • Fault Log Decoding with Linduino PSM &mdash AN155
    PDF, 230 Кб, Файл опубликован: 26 янв 2017
  • In Flight Update with Linduino &mdash AN166
    PDF, 1.1 Мб, Файл опубликован: 10 апр 2017
Статьи
  • Dual Output DC/DC Controller Combines Digital Power System Management with Analog Control Loop for ±0.5% VOUT Accuracy &mdash LT Journal
    PDF, 3.8 Мб, Файл опубликован: 20 янв 2012
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | External Power Switch Buck Controllers
  • Power Management > Switching Regulator > Digitally Programmable Regulators
  • Monitor, Control and Protection > Digital Power System Management > DC/DC Regulator With Power System Management
LTC3880IUJ-1PBF, LTC3880IUJ-1 PBF, LTC3880IUJ1#PBF, LTC3880IUJ 1#PBF
На английском языке: Datasheet Linear Technology LTC3880IUJ-1#PBF
Публикации по теме
