Datasheet Linear Technology LTC3882IUJ#TRPBF — Даташит
СерияLTC3882
МодельLTC3882IUJ#TRPBF
Dual Output PolyPhase Step-Down DC/DC Voltage Mode Controller with Digital Power System Management
LTC3882: Dual Output PolyPhase Step-Down DC/DC Voltage Mode Controller with Digital Power System Management Data Sheet
PDF, 1.4 Мб, Файл закачен: 27 мар 2018
13 предложений от 10 поставщиков
, Dual Output PolyPhase Step-Down DC/DC Voltage Mode Controller with Digital Power System Management
LTC3882IUJ-1#TRPBF
373 ₽
LTC3882IUJ-1#TRPBF
512 ₽
LTC3882IUJ#TRPBF
703 ₽
LTC3882IUJ-1#TRPBF
Корпус6x6 QFN-40
Код корпусаUJ
Индекс корпуса05-08-1728
ADC16-Bit
DAC12-Bit
Demo BoardsDC1936A,DC2174A-A,DC2174A-B,DC2252A-A,DC2291A
Design ToolsLTspice Model,LTpowerCAD File,Linduino File
Экспортный контрольнет
Основные особенностиBurst Mode, Differential Remote Sense, PolyPhase, PMBus, I2C Control, EEPROM, ADC, DCR Current Sense, Sequencing, Margining, Tracking, External Synchronization
FunctionDC/DC Regulator With Power System Management
I/OPMBus/SMBus/I2C
Isupply32 мА
MonitorsVin, Iin, Vout, Iout, Temperature and Faults
Количество выходов2
Диапазон напряжения питания3V to 13.2V
Vin Max13.2 В
Vin Min3 В
  • Accurate Temperature Sensing with an External P-N Junction &mdash AN137
    PDF, 540 Кб, Файл опубликован: 20 сен 2012
    Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.
  • Overview of the EEPROM in LTC PSM Devices &mdash AN145
    PDF, 3.0 Мб, Файл опубликован: 10 май 2014
  • Modeling and Loop Compensation Design of Switching Mode Power Supplies &mdash AN149
    PDF, 1.4 Мб, Файл опубликован: 23 мар 2015
  • Power System Management Addressing &mdash AN152
    PDF, 169 Кб, Файл опубликован: 12 июл 2016
  • Linduino for Power System Management &mdash AN153
    PDF, 1.3 Мб, Файл опубликован: 24 фев 2016
  • Fault Log Decoding with Linduino PSM &mdash AN155
    PDF, 230 Кб, Файл опубликован: 26 янв 2017
  • In Flight Update with Linduino &mdash AN166
    PDF, 1.1 Мб, Файл опубликован: 10 апр 2017
Статьи
  • High Step-Down Ratio Controller Combines Digital Power System Management with Sub-Milliohm DCR Sensing and Accurate PolyPhase Load Sharing &mdash LT Journal
    PDF, 406 Кб, Файл опубликован: 27 окт 2014
Серия: LTC3882 (4)
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | External Power Switch Buck Controllers
  • Power Management > Switching Regulator > Digitally Programmable Regulators
  • Monitor, Control and Protection > Digital Power System Management > DC/DC Regulator With Power System Management
LTC3882IUJTRPBF, LTC3882IUJ TRPBF
На английском языке: Datasheet Linear Technology LTC3882IUJ#TRPBF
Публикации по теме
